Hello,
I want to buy a lathe with some parts in mind.
I was looking at Holzman ED400 FD lathe.
I need to turn a 8mm in diameter 40mm stickout brass shaft with h8 tolerance (+0; -0.022 mm)
Also I need to ream a 8mm hole in a 10mm brass rod(same stickout), also with a H8 tolerances.
My question is if you profesonals could adjust such level machine to achieve these results? The work amount to achieve the result is not that important, that kind of work is enjoyable for me
