ian3846
- Apr 6, 2009
- Australia, Gladstone
Hi guys
So I have a client that requires a 8um to 11um surface finish to be produced on a vertical mill. While this is 100% achievable on the centre line of the cutter, due to the nature of a vertical mill as you move away from the centre the actual surface finish decreases in courseness and then the step of the cutter modifys the surface finish again. I have been able to produce something that pretty close using a high feeed cutter with a 50% Step over and when comparing with a scratch gauge it is comparable but visually it has a rail road effect that the client is concerned about.
Despite my best attempts to explain to the engineer looking after the project that it is within the drawing specs and using a vertical mill the above issues are unavoidable he is still not happy with it.
Apart from machining a piece of steel with straight lines using a engraving tool to produce a 8um to 11um surface finish and using it as a forming die to produce the correct finish on the aluminum I'm all out of ideas.
Any thoughts or ideas would be appreciated.
