ACRA Mill Head Repair
Likes Likes:  0
Results 1 to 5 of 5
    Sep 2008
    6
    Default ACRA Mill Head Repair
    I have an ACRA Model 18VH vertical mill variable speed head disassembled to repair the drive components. I had expected to find some plastic bushings in the drive pulleys as is common in BP's and several other brands. However, as best I can tell there are no bushings. The movable pulleys are machined to run directly on the shaft. The sliding spindle drive pulley seems to be in good shape. The motor sliding drive pulley has about 0.017" clearance over the motor drive sleeve. Also the movable motor drive pulley has a bearing surface only at the top near the belt track. has anyone run into this before? Any creative repairs?
    Keith
    Jan 2006
    Angier, North Carolina
    2,589
    1074
    956
    Any pictures available?
    Sep 2008
    6
    Quote Originally Posted by awake View Post
    img_1125.jpgLower motor pulley and motor shaft sleeve. Keyway on sleeve is trashed but not a big deal.
    img_1126.jpgTop of motor drive pulley showing bearing surface
    img_1127.jpgBottom of lower drive pulley showing no bearing surface
    Sep 2008
    6
    img_1133.jpgLower motor pulley non-bearing end diameter
    img_1150.jpgLower motor pulley bearing diameter
    img_1132.jpgMotor sleeve diameter
    Sep 2008
    6
    Well the good news is I have been able to obtain repair parts from ACRA. The parts are a better design than the original. The bushing in the original lower motor pulley was about an inch long. The new pulley has a bushing that is about 3 inches long. Failing finding the repair parts I was prepared to bore out the original part and make an insert to press in.
