One of the scales on my Acu-Rite 200S DRO does not work. I swapped the cables and confirmed that it is not the monitor. Any suggestion on troubleshooting the problem? Does anyone do repairs on these? The part number is 558111-08.
The read head slides out the end of the scale once the end cap is removed. That, at least, will give you a chance to look it over for mechanical problems.
I have had a couple issues in the past, with the head coming adrift from the spring arm that holds it against the scale. In one case the supplier of the lathe had put one on that was too small by about half an inch, and it banged into the end when the slide was at full travel. AcuRite took the old one back and sent us a new one.
My experience with dicking around with this sort of stuff has been that the majority of the problems with electronic stuff seem to be mechanical. Broken wires, bad solder joints, etc. Worth having a peek, anyway. Based on my experiences, you pretty much gotta be one of those that thinks the solution is a bigger hammer, to easily make anything worse.
Once the end cap is off, you can slide out the lip seals and see if the glass scale itself is intact. Get thee some lint free wipes and some alcohol to clean the scale. A pair of plastic tweezers would be of use there.
Failing that, post the travel length and the resolution you require, and like as not, someone has one around, for not too dear. Looks like 8 inch and 1 micron, from the part number. Correct?
Cheers
Trev
Have you checked the plug end of the lead to that reader head? Equally have you blown the head out with clean compressed air? Only takes one small spec of dust in the beam path to make em totally dead.
DROs have cables in motion. Before you spend a lot of money, you ought to try to check the cable itself. It's probably hard-wired at the read-head, but if you can gain access to the wire ends it would pay to check continuity for each wire back to the pins at the display end. If necessary, you could puncture the insulation with a needle probe to make that check.
I'm in communication with Jon now. Thanks for the heads up.Beeser,
A member here to contact would be HWElecRepair
he can probably help you.
spaeth
At this point I see no reason to abandon the Acu-Rite system already on the lathe although the cost of a new replacement scale is expensive. Are there other scales from a different manufacturer compatible with the Acu-Rite 200S?
Call DROPROS. They can help you.
DRO PROS Digital Readout beats Heidenhain Newall Acurite Sargon Fagor
There are many scales that will work. There are two basic forms of quadrature scales - those with index (homing) marks and those without. Not sure what the 200 uses. Size will be an issue (and may limit your choices) if you are replacing the cross slide scale - sounds like you are.
Genuine Acu-rite scales will cost more, but they are good quality. If you chose another brand you may need to remount it; that can be time consuming to get "right" and you may need to make mounts for the head/scale. I just installed a 68 inch (yep, a bit longer than yours) scale with three mount points on rough castings. Took the best part of 2 days to make the mounts and get it dialed in.
Can you explain how they work in a paragraph? I googled and got lost immediately.Today in the general encoder world magnetoresistive scales have taken over. The big advantage is the reliability and fairly low cost. They are sealed and don't suffer from vibration or contamination issues. I work with a couple vendors that produce magnetoresistive scales both rotary and linear.
I am at a loss why the DRO and CNC industry has not embraced magnetoresistive scales.
It's still Sunday in Canada. Are you half buzzed? Have a read of it again. I think you are in violent agreement. Then try not to punch yourself in the nose.??? I don't know where you've been or what your talking about, but my lathe and mill both use magnetoresistive technology. Both 1um .
Notice
