viper
Titanium
- May 18, 2007
- nowhereville
We are working on an electronics display unit that will require a lens to cover the display. The only way we can see at this point is to machine a bevel into the case and set a lens down into it. We would apply glue before setting in place.
This will be an out door devise and subject to all sorts of pressure washing, thermal deltas, vibration, etc. We are envisioning something similar to windshield adhesive but it needs to be clear. There is also concern of adhesion to the polycarbonate. Well, actually there is a sun shield film that is adhesed to the lens material so the glue would stick to this film.
We only need a small amount and would apply with a paint brush. Anything other than clear would be a problem. We are not bound to polycarb but it does meet our impact requirement and is durable. Acrylic might also work if it is proved to be better in the sun.
So - requirement
Adhese polycarb or similar plastics to Aluminum
Very high bond strength - (never come off kind of strong)
clear in color
Will allow a small amount of thermal expansion due to expansive properties of the 2 materials.
Does this sound doable?
So - requirement
clear in color
