Is there amy merit to radius the bolt ends for holding down tools on lathes or fixtures for the purpose of having a point contact on the tool?
Whatever you use, I find it pays to remove the threads on the ends (to just below minor dia) so that they don't flare out and can be removed easily when they break etc etc
Use square-headed Unbrako.
I thought - ''blimey, that's going back a bit, haven't seen Unbrako squares for eons '' ..they're no longer listed Ted.
Yes, but the square heads are much better for this application because they can't get clogged up with chips. Socket head versions are a bit of a time waster because you will have to blow them out from time to time. The trouble is that square heads are much less common and will cost you more when you need to buy new.
http://www.unbrako.com/images/downloads/unbrako_catalog.pdf
I totally agree billmac, I hate hex socket toolpost bolts, .........I make my own SQ heads (usually from EN3B and Casenite them.)
.Is there amy merit to radius the bolt ends for holding down tools on lathes or fixtures for the purpose of having a point contact on the tool?
Along the lines of the square head vs socket head comments, why the bloody hell do tools have Torx and Allen socket screws for the inserts. Grrr.
T15 male Torx would be a step in the right direction...
Notice
