Adjoining aluminum NO welding
Likes Likes:  0
Results 1 to 10 of 10
    Oct 2016
    Indiana
    51
    5
    Default Adjoining aluminum NO welding
    Im wanting to build an aluminum framed table (18H x 48L x 30W) that can hold a weight of about 300 lbs. This will be a fire pit table, so my joints cant be those composite T fasteners. I was curious what the best method would be for adjoining the tubing pieces that meet.
    I have access to plenty of 1 and 1.5 square aluminum tubing as well as the 90 angle.
    Some of the common methods Ive seen are adhesives, rivets and nut/bolt.
    Apr 2011
    Nebraska
    1,211
    1686
    353
    What is wrong with rivets or nuts/bolts?
    -Ron
    Sep 2006
    SE PA, Philly
    5,293
    982
    1753
    Why no welding?
    Apr 2004
    Modesto, CA USA
    6,739
    1118
    Outdoors dissimilar metals will cause the aluminum to corrode.
    May 2006
    Seattle
    1,856
    34
    341
    Quote Originally Posted by Bill D View Post
    Um, weld it with aluminum wire?
    Mar 2017
    LATVIA
    301
    76
    163
    unless there is a need for that table to be light, using aluminum because it is "free" seems like the wrong choice, need AC tig (or proper mig setup) to weld it, screws and rivets may make that frame look not exactly aesthetically pleasing, and you can forget about glues, even painting it may not be straight forward
    steel or stainless steel is a lot better choice, even if you need to pay for it
    and avoid stainless hardware in contact with aluminum, it will make aluminum corrode, use galvanized nuts/bolts/rivets if you have to
    Oct 2003
    East Peoria, IL, USA
    5,384
    336
    786
    Simple gusset plates & rivets like airplane construction. or rivet nuts and screws. or through bolted.
    Luis & Fab's RV-7A Construction Log >> Blog Archive >> Riveting the Firewall
    Nov 2013
    Eastern Massachusetts, USA
    4,089
    4406
    4295
    Miter the horizontal pieces at the corners and mount them inset behind the legs so the joints don't show. You can make L brackets out of heavy aluminum angle to fasten the horizontals together with long through bolts fastening the frames to the legs (through one frame piece only). You will have access inside the legs for nuts before the top is installed. Don't forget spring washers to keep things tight with temperature change.
    Nov 2003
    Beaumont, TX, USA
    4,904
    171
    1487
    Stainless screws are OK for use with outdoor aluminum.
    Jan 2016
    New York
    25
    19
    Fire pit table out of aluminum...
    Will this be in close contact with the fire? If so, aluminum is a terrible material choice. The flames will oxidize it and in short order, you will have a scorched hole in your table. What's worse is if you burn wood or charcoal in it and then it rains, or you have a heavy dew. The water combines with the ash and makes lye. Lye eats aluminum like my kids east M&Ms.
    Or, if you're building a table and putting the flames on top, like a hibachi, you need to be careful because aluminum conducts heat extremely well, and 70F aluminum and 300F aluminum look exactly the same. Guests with burnt arms won't be happy...
    But, if you're trying to build a light table to have near-ish to your fire pit... fine, and everyone here has given good advice. Just keep the aluminum away from the actual fire.
