So I got into a situation I have never run into before. Unfortunately, I have to explain the whole scenario before it makes sense why I am asking.
So I am reassembling the vertical spindle for my horizontal mill. The direction change (horizontal to vertical) is done with a bevel gear that resides on the center of the spindle. See picture of the apparatus:
Notice the nut that holds the gear in place (it is the same nut as the bearing preload nut). The nut is split, (see picture), with a socket head cap screw to allow you the adjust the split. You can see (a little) in the picture where after the factory (?) assembly, the split adjustment screw was ground down to be flush with the nut, which allowed me to see where this screw was originally positioned. Additionally, there is a set screw with a copper plug against the threads.
When reinstalling, I realize it was critical that this nut was tight against the gear as it coming apart would certainly be bad news for the unit.
So I left the adjustment screw semi loose and set screw loose, ran down the nut with a my spanner wrench, then gave the wrench a couple good whacks with the rubber mallet to make sure it was tight. When I went to tighten the split adjustment screw and noticed it was not tight, and to get it tight I had to go past the ground down part of the screw. This made me think that perhaps I needed another turn on this screw.
So I loosened the nut, tried to get another turn on the screw, but this made it too tight to turn the nut down (lot of interference). So I adjusted the screw so it was just barely in tension, then again, screwed down the nut, gave the wrench a good whack or two with the rubber mallet, and then tightened the adjustment screw. Again, it tightened PAST the ground down section (why I do not know) but it got tight, and then I tightened the set screw securely.
So I went on and installed the top tapered roller bearing. The preload nut for the bearing is a similar nut (little smaller thread, so I did not get the two mixed up). I did a similar routine for that nut, although I used less torque given this was a bearing preload. Just some light taps to make sure it was taught, figuring I would have to tighten again after bearing break-in. Again, the screw, it tightened at all prior to installation, made the nut too hard to turn, so I again, left it just in tension, screwed down the nut, tightened the adjustment screw, then the set screw. All seemed to be fine.
Fast forward to the next day: I subsequently had to remove the top nut to check a marking on the bearing. When I did, I found a few little skinny metal shards under the nut threads. Nothing like actual threads stripped, just super skinny but long pieces, one of them was copper (remember, the set screw has a copper plug against the threads. I did notice, that the threads on the spindle showed quite a bit of chatter marks and were far from smooth. Not sure if this meant everything was never cleaned up very well, and these shards are just the nut and spindle seating together, or if something was wrong with the way I assembled everything.
Anyway, in short my question is this:
1. I'm concerned that if the top nut created some metal shards, did the bottom nut as well, and they are just waiting to come loose and get in my new spindle bearings? Should I disassemble the head again and check? What should I do differently?
2. Did I do something wrong in how I assembled these nuts? Is there a correct way/order of operations to tightening a nut like this? Was getting them tight with the rubber mallet too tight? (keep in mind, this was me with a big screwdriver holding the NMTB40 lugs with my leg and hitting a 6" handle spanner wrench, not clamped in a vise with a 24" Stilson.
