Advice for drilling solid copper
Results 1 to 19 of 19
    Oct 2021
    Indiana
    Default Advice for drilling solid copper
    Hello everyone. Needing some help with drilling a .062 hole into .130 diameter material on a lathe. My current program reads as follows
    G97 s1000 m13;
    M98p1;
    T4x0.;
    Z.2 s3000;
    G1 g99 z-.65 f.0005;
    M98p1;
    I'm running on an older hardinge lathe, with barely any stock protruding from the face of the spindle and it pulls out to part length after it drills to prevent the stock from bending. Chuck pressure is all the way down to 30psi to prevent crushing. Carbide through coolant drill.
    I've managed to make 1 part and the drill broke on the second. I've tried many different speed and feed combinations with no consistent luck. Does anyone have any ideas what to do to get this thing to run consistent? Thanks in advance
    Aug 2004
    Virginia
    2,974
    248
    1400
    It kind of depends on if you have the equipment to change the profile of your carbide bits. Copper is gummy and grabs pretty easily. That is probably the reason you broke your bit. It is a common practice to dub the bit when drilling copper to keep it from grabbing. If you don't have the equipment to change the profile of your carbide bits then I would go to a standard bit and dub it.
    Feb 2004
    peekskill, NY
    27,598
    6488
    What is the top spindle speed on this machine?
  4. Likes Mtndew liked this post
    Oct 2021
    Indiana
    I am honestly not sure
    Oct 2021
    Indiana
    Thanks! I'll give it a shot
    May 2017
    Minnesota
    2,308
    3187
    1677
    Might be better off with a cobalt drill instead of carbide.
    Jun 2012
    Michigan
    6,296
    5881
    4025
    Quote Originally Posted by Emilyfinchum View Post
    G97 s1000 m13;
    That's 16 SFPM. WAY too slow.
    You need to spin at least 4,000rpm if your machine can go that fast.
  9. #8
    Feb 2004
    peekskill, NY
    27,598
    6488
    Quote Originally Posted by Mtndew View Post
    I think 100 SFPM is about right. For a 1/16 dia drill that's about 6000 rpm
    0.062 X 3.14 = .198 inch circumference = 0.0165 feet circumference
    100 ft/min / 0.0165 feet = 3030 rev/min
    What's the max speed on the lathe?
  10. #9
    Aug 2021
    Florida
    9
    34
    I had a somewhat similar situation. Went to straight flute drills. That took care of it for me
  11. #10
    Aug 2015
    Illinois
    1,755
    1373
    750
    Quote Originally Posted by Woodeye1 View Post
    Are you referring to a half round drill?
  12. #11
    May 2021
    Virginia
    346
    379
    89
    Quote Originally Posted by Illinoyance View Post
    McMaster-Carr
    Maybe these.
  13. #12
    May 2021
    Virginia
    346
    379
    89
    Thought it was standard practice to "brass off" the edges on a twist drill if you're going to drill something soft like copper. Basically just dull the cutting edges a bit. I usually just drag the cutting edges over a fine stone or use a diamond file.
  14. #13
    Feb 2004
    peekskill, NY
    27,598
    6488
    I advise against dubbing the edge on a 1/16 drill going into copper.
  15. #14
    May 2021
    Virginia
    346
    379
    89
    Quote Originally Posted by jim rozen View Post
    Ehhhhh... I think it's worth a shot. Especially since they're doing this on a CNC machine. More torque on the drill bit, but it aught to be less "grabby".
    Could also try peck drilling.
    Maybe use a sharp drill and go at a more conservative feed rate?
  16. #15
    Mar 2020
    New Jersey
    60
    120
    16
    My grandfather turned a good amount of copper and he used straight flute drills. At first I thought they were reamers. He also used milk instead of a cutting oil.
    Not sure if these drills are available today. I dub the cutting edge and also the flutes on one set of drills. I mark these drills with blue dykom on the shaft so I do not mix them up with other drills.
  17. Likes 52 Ford, boslab, MilGunsmith liked this post
  18. #16
    Sep 2007
    Maryland near DC
    420
    90
    88
    Back in the day we machined a lot of OHFC copper. Holes were typically much smaller, ~0.020”. No attempt was made to dub them. Drilling was always done by hand with a sensitive drill chuck. The only lubricant used for copper was lard oil.
  19. Likes MilGunsmith liked this post
  20. #17
    Feb 2004
    peekskill, NY
    27,598
    6488
    Quote Originally Posted by mnl View Post
    Our standard lube for copper is 50/50 kerosene/lard oil. Dead sharp drills. The drill breakage mentioned is probably because of low spindle speed and excess feed rate per turn.
  21. #18
    Jan 2007
    wales.uk
    1,918
    438
    455
    We used tallow in work, came in big sticks for Ali saws
    Had a funny thought, we used a big pacemaker lathe to machine copper Lance tips, like 25’ centres, I was imagining cleaning the drip dray from swarf flavoured yogurt, not nice
    Electrical copper was a pig, beryllium copper was fairly tolerable
    Mark
  22. #19
    Nov 2002
    3,414
    2131
    899
    G97 s1000 m13;
    M98p1;
    T4x0.;
    Z.2 s3000;
    M98p1;
    I just finished drilling 0.039" holes through 1" of 99% pure copper.
    The drill was a standard, jobbers drill. Nothing specialized for copper or anything.
    I broke the first drill trying to do it manually.
    Then I changed to the cnc mill, flooded the drill with coolant, & pecked it out.
    S8000M3
    M8
    G00 G43 Hhh
    X.xx Y.yy
    Z.zz
    G83 X.xx Y.yy Z.zz F0.0008 Q0.01
    G80
    It worked beautifully, and ran with no problems.
    Doug.
  23. Likes 52 Ford liked this post
