Advice on machine/ setup/ cutter needed for job
Results 1 to 19 of 19
    Feb 2020
    Illinois
    Question Advice on machine/ setup/ cutter needed for job
    I’m currently working on developing a new part and am looking for advice on how to go about making a specific feature. I do not have access to cnc and will need to do this op on a manual mill. In the attached pictures shows the two opposing channels through a rotor for a musical instrument. The channels aren’t simply straight cuts with a ball mill but curve in and out of the rotor. Hopefully that feature is apparent in the pictures. How would I cut this without a very complicated and unreliable setup? I’d rather not shop this op out because I’ve already gotten a quote and it seems steep. The o.d. Of the part is .875 in. and the diameter of the channel is .468 in. Material is c360.
    Oct 2015
    AUSTRALIA
    73
    22
    Do you have a horizontal spindle? all I can think of is setting it up on a rotary table and using a full width lollipop cutter. I don't think this is really possible in a cost effective fashion on a manual machine.
    Jun 2012
    Eastern PA
    1,001
    287
    458
    What is the material?
    Get a 15/32 end mill and "drill" the 2 channels while the part is held in a fixture that clamps it to keep it from rotation.
  4. Likes Booze Daily, Limy Sami liked this post
    Sep 2015
    Ohio
    1,226
    801
    1232
    ^ What he said.
    I think I'd rough it with something smaller first just to clear out the center.
    I'd probably go with a 4 flute just so it doesn't bounce around too much in the interrupted cut.
  6. Likes Limy Sami liked this post
  7. #5
    Jun 2012
    Michigan
    5,010
    4555
    3017
    Turn them oversize, drill the 2 holes, turn them to size. Easy peasy.
  8. Likes Limy Sami, jariou, rcoope liked this post
  9. #6
    Nov 2016
    FINLAND
    293
    30
    26
    Drill First the holes and maybe bore/ream for roundness and surface quality, Then turn to size.
  10. #7
    Sep 2002
    People's Republic
    3,876
    344
    2455
    He said they are not straight channels
    I would say if those two cuts are not straight you need an indexing head. hold it in a 3 jaw, bore then rotate back and forth to get what you want
    If they are straight and just look complicated, then the previous advice holds.
    I think you need to clarify
    If they are straight drilled vertically, then they are simple, maybe a fixture to hold them and keep the burr down
  11. Likes MaCon liked this post
  12. #8
    Oct 2005
    16,639
    Quote Originally Posted by momalleyhorns View Post
    Screen shots of solid model aren't' showing any tolerances.
  13. #9
    Jul 2004
    Houston, TX USA
    30,477
    You could answer this question - if varying thickness you need a ball shaped cutter possibly
  14. #10
    May 2011
    New Jersey
    2,422
    213
    1309
    I'm all for manual ops, but sometimes it's cheaper in the end to get someone with the right tools to bang em out. Might even be cheaper in the long run.
    Maybe post a rfq in the rfq section. You might be surprised.
  15. #11
    Nov 2014
    Florida
    4,131
    1620
    1941
    If this is a prototype, 3d print the OD's oversize, the channels to size, and fit up as needed. Good reason to buy a 3d printer??
  16. #12
    May 2005
    AZ
    2,376
    221
    807
    Looks like a French horn rotary valve body, or some other very similar application. If indeed the 2 cutouts through the body don't follow a straight line, do they follow a known constant radius value? If so, then you COULD set up a final machining step using a rotary table and the proverbial "lollypop" cutter, but that should be done only after roughing as much material away as possible. That is assuming you don't have a radius value of 48" or so, as the radius you would be able to make with manual setups like that will be limited to machine travel envelope and where you can set up a rotary table relative to spindle. Looks like you have some 3D modeling skills, so you can figure out the max size straight path and get the stock down to something (maybe) manageable with end mills to start.
  17. #13
    Sep 2006
    Stillwater, Oklahoma
    1,394
    103
    755
    I rather suspect the cutouts are straight cylindrical sections and the confusion about them being odd from his first post is that he realizes he can't just lay it on its side and cross it with a ball end mill. The two drills would indeed work.
    It seems like lots of the viewers and responders are really thinking in 3D and imagining a curved track like a worm hole through the part and a shape that would require the lollipop cutter. However, if it's a functioning rotary valve it's only the shape of the peripheral opening that's important. Whether the air travels straight across or follows a curved path to it's intended exit should be immaterial. And it would be nice if the OP showed up again to enlighten us.
  18. #14
    Feb 2020
    Illinois
    They are not straight indeed they have a curvature which is why I’m having trouble wrapping my head around it.
  19. #15
    Feb 2020
    Illinois
    Yes they are not straight channels they curve in and out of the valve body. Imagine these parenthesis were the centerline of the channel: )(
  20. #16
    Feb 2020
    Illinois
    I think you may be right. The trouble is I know parts with this feature have been made on manual machines in the past.
  21. #17
    Oct 2015
    AUSTRALIA
    73
    22
    Yeah when labour was cheaper and there wasn't an easier way?
  22. #18
    Virginia
    29,053
    7561
    9036
    Ball end mills. Stock rougher, then custom-ground finisher.
    Swing arm fixture, appropriate radius off the pivot. Short as the arc needs to be, don't even need a rotab.
    Could have been hand cocked, cut then pulled though with a handlever, spring, or simple pulley and weight.
    It's only 360 Brass. ".... has the highest machinability of all copper alloys.."
  23. Likes tdmidget liked this post
  24. #19
    Apr 2010
    Surrey, England
    369
    1000
    71
    Nobody going to mention a cherrying head on a Bridgeport?
    Dave H. (the other one)
