trochoidalpath
Cast Iron
- Jan 17, 2016
Roughing in power in some new shop space and I am having a moment of self-doubt.
Placement and quantity sound good? Anything I should be thinking here about that I'm not? I'm definitely optimizing for flexibility, not entirely sure where equipment is going yet.
- 120V power receptacles: 2 duplex, every 8 feet, mounted at cabinet countertop height + 3 inches
- 240V power receptacles: 1 each 30A 1-phase and 3-phase, every 8 feet, mounted at 6.5 feet above floor. IEC 60309 (pin-and-sleeve style) receptacles, angled 15 degrees off the wall and pointed down.
- Separate 240V power receptacle 60A 1-phase near the big door, mounted at the same height, in case I need to get some welding done
- Compressed air: Transair hard line run 8" below the ceiling around the perimeter of the room in a big loop. Drops are every 8 feet and terminate 6 feet above the floor; each drop has a valve ahead of a duplex 45-degree air fitting.
