Ike Carlson
- Jun 16, 2019
I'm finally making some progress on my shop air compressor. Here is what I have so far...
-120 gallon vertical lp tank (super heavy) I will hydro test to 300+ psi
-Airbase EMAX APP210524T 5 HP 2 stage compressor
-3hp 3 phase motor running on a vfd
I tore the compressor down and am making sure everything is good before putting it into service.
I believe the pump is rated at 800 rpm and the minimum is ~500 rpm. I'm planning on running it at ~600 rpm so I can use my 3hp motor.
Do you guys think the 3hp motor will do ok?
