Soooooo BILLET PISTONS?
Programmed via Mazatrol
Probably easier to have a piston company make them, then you sell them then. Working with pistons is kind of a bitch, making them out of solid would be a pain, and your choice of materials is limited. I'm a do-it-yourselfer myself but still, sometimes it makes more sense to go to someone who is set up for it.This isn't for one, but hundreds of pistons.
Are the skirts cammed ? Even if they are, and you're set on it, there's Van Norman piston grinders out there cheap, you could do that as a finish op.So where I'm at is the "why" part.
I get pistons are kinda complicated, but I would genuinely like to know what would stop me from making them from 6061 on a very accurate 2 axis Mori lathe followed by a couple ops on a VMC with a 4th?
If its going on a 4th for second op, program your cam and taper in and cut it with a ball mill , beings on a compressor probably won’t need much of either, just guessing
I don't recall any compressor pistons having much more than .004" drop @45 from the major OD from my (too much) time working at a place making pistons for a living. In regard to the material, they were never made out of anything other than 2618 or 4032 during my time there. 6061 was only ever used for non-piston things.
One thing that that no one else has mentioned is to make sure that the flatness/angle of the ring grooves is close to 0 with any deflection pointed toward the crown.
Notice
