I figure someone here will have dealt with this before. I have a new IR Garage Mate 20 gallon compressor. I've been using it mostly with the air nozzle to blow out chips but used it today with an airbrush applying cerakote. I set the regulator to 25 psi and starting painting and within a minute there was no pressure and the compressor had not kicked in. The tank air was over 120 psi and regulator was reading 0. I turned the regulator back to 25 and the same thing happened again. During troubleshooting, I used a 25' 3/8" with a 1/4" adapter to an air gun. It seems no matter what I set the regulator to the pressure drops by half or more. When I stop discharging air it will rise back to about half of that but not where it's set.
All the threads I've read talk are from people running theirs at much higher pressure than my measly 25 psi. I figured the thing would run for 15 minutes or more at stay at 25 psi before the motor would kick in but that doesn't seem to be the case.
I talked to IR support and they're sending me a new regulator "hoping" that's the issue. Anybody have other ideas?
