Aloris BXA or CXA QCTP?
Results 1 to 9 of 9
    Jan 2015
    Arizona
    190
    11
    Default Aloris BXA or CXA QCTP?
    The Aloris catalog recommends a CXA QCTP for my Victor 1440G (Acer 1440G) but the width of the post body is about a 1/4" larger than the width of my compound. The BXA is 1/4" in the other direction. My sense is that any overlap is not doing any good in supporting the post so why not just get the BXA. Also, the height of the BXA seems about right. Or am I missing something?
    Feb 2007
    St. George, Utah
    665
    229
    373
    I use a BXA on my 13" Sheldon. Its a perfect fit. There are times when I need to slide the tool post to one edge or the other of the compound so I wouldn't worry too much about matching the width.
    I've not noticed any of my tool holders getting anywhere near topping out, so I'd assume the BXA would be big enough for your 14" lathe, but there are wiser guys than I!
    Jan 2017
    Oregon
    1,732
    315
    1226
    I have a BXA on my 13" Clausing 1300 and a CXA on my 15" Colchester.
    I like the CXA better, it's just bigger and more rigid.
    Nov 2007
    marysville ohio
    8,998
    2528
    5755
    I have CXA's on my 13" Holbrook, 15" LeBlond and 16" South Bend. It seems just right for all 3. CXA will hold a bigger tool than a BXA.
    May 2003
    Iowa
    10,496
    3616
    4257
    I've got a CXA on my 1500 Clausing. Unless you're doing a lot of really small work, that's what I'd run. It all depends on what you plan on machining. If it's all small stuff, the BXA takes up less room and costs less. I'm always getting that part that I can just barely fit in the lathe.
    JR
    Jul 2008
    Philadelphia
    1,910
    497
    432
    Love my Aloris CXA on my victor 1640.
    Jan 2015
    Arizona
    190
    11
    Quote Originally Posted by doug8cat View Post
    I can see how the CXA would be a perfect fit for the Victor 1640, a lathe that I would prefer to have.
    Mar 2006
    Wisconsin
    952
    13
    323
    Page 2 of the Aloris catalog gives the dimensions for the tool posts.
    http://www.aloris.com/wp-content/upl...is_catalog.pdf
    It appears either a BXA or a CXA will work on a 14" lathe. BXA is listed for use on 10" to 15" machines while the CXA is listed for 13" to 18" machines. As for tool size there are several manufacturers that make tool holders that will accommodate larger than the standard tooling. I have a couple tool holders for my BXA tool post on a Sheldon MW-56-P that permit the use of 5/8" tooling.
    Jan 2017
    Oregon
    1,732
    315
    1226
    Quote Originally Posted by projectnut View Post
    ...I have a couple tool holders for my BXA tool post on a Sheldon MW-56-P that permit the use of 5/8" tooling.
    Standard for BXA is 5/8" shank. The BXA-1S (oversize) is 3/4".
    The CXA is standard 3/4" and oversize is 1".
    I use 3/4" tooling on both my lathes, I just opened up the slot on the BXA 5/8" holders...
