Alternate ways of finishing a stainless steel sheet.
Results 1 to 20 of 20
    Mar 2009
    4,982
    89
    914
    Default Alternate ways of finishing a stainless steel sheet.
    1. Mounting a brush in a mill head and sweeping across the surface.
    2. Use same brush but do not sweep, come down on sheet every few inches and make consistent pattern.
    3. 400 or 600 grit brushed on surface.
    4. Bead blast.
    5. Chemical dip.
    Involve a .057 sheet of stainless.
    I also want to cut 26 slots .090-.100" wide and 1.5" long. I have not checked anywhere yet. But would a 3/32 bit do this or will I be breaking half a dozen cutters before the job is done. This would be a grill cover for a fan. Another way is to cut out a larger hole and cover it with a custom grill, with one screw in each of four corners.
    I got the sheet at Alan Steel from a pile of stuff that probably came out of a restaurant kitchen. Probably sitting there for at least 3-4 years.
    For any of the locals who don't know about Alan Steel in Redwood City. Get knowledgeable. I asked the owner if I could take some pictures and post them here. He asked me not to do that because he doesn't want to advertise. Local business is plenty.
    Thank you for any advice.
    Feb 2008
    Mishawaka, IN
    341
    39
    79
    I'd be punching the slots with a ironworker and using either a stroke sander or belt sander to put a #4 brush finish on it.
    Sent from my E6910 using Tapatalk
  3. Likes Scottl liked this post
    Nov 2013
    Eastern Massachusetts, USA
    4,146
    4453
    4335
    Quote Originally Posted by danil View Post
    What he said but if you are looking for a more decorative finish than plain brushed turning the part 90 degrees before the final pass gives an attractive cross-hatched look.
    Oct 2005
    14,876
    I would coarse sandblast to even everything out (and get rid of machining/punching marks)
    And then work it down from there with scotchbrite/wirewheel/sandpaper etc.
    Dec 2012
    Se Ma USA
    1,489
    115
    837
    Perfect job for a laser, apply finish first.
    3M makes some really good abrasive brushes in cup and wheel form. And they last a real long time.
  7. Likes jrmach liked this post
  8. #6
    Sep 2012
    NW Iowa
    245
    131
    191
    Either finish it with a Dynabrade finishing wheel or glass bead blast it. When I fabricated stainless rotational molds, we used glass bead blasting for the interior surface finish. It's a softer finish than a shot blasted finish (and steel shot blasting will rust from the residual shot).
  9. #7
    Dec 2014
    Arizona
    369
    39
    62
    For finishing -
    #1- time saver #2 stroke sander
    How big of sheet?
    For slots -
    Punch
    Laser
    Plasma
    Water jet
    Plenty of ways to skin a kitty.
  10. #8
    Mar 2009
    4,982
    89
    914
    Quote Originally Posted by azmachining View Post
    For finishing -
    How big of sheet?
    For slots -
    Punch
    Laser
    Plasma
    Water jet
    It's a small sheet about 3" x 8". A bulkhead for a VFD.
    I don't have any of that stuff for cutting slots.
    Found a ball type hone I used for a engine cylinder. Might try to spin it in a drill chuck and run it over the surface in a random fashion.
  11. #9
    Apr 2004
    Modesto, CA USA
    6,812
    1136
    Get a flat grinding wheel mounted on a dremel shank say one inch diameter. Use that flat circle end onto the work in a dril lpress in a overlapping pattern to give it the engine turned look. I suppose a small cup wire brush could do it as well.
    The classic method is a wooden dowel and grinding compound
    Bill D.
  12. #10
    Jan 2010
    North Carolina
    170
    266
    90
    Quote Originally Posted by Bill D View Post
    Bill D.
    Craytex round abrasive sticks chucked in a mill or drill press also work well for this.
  13. #11
    Jan 2007
    Norfolk, UK
    18,723
    14244
    14267
    The Q was ''Alternate ways of finishing a stainless steel sheet. '' …
    Etch primer and colour coat of your choice ?
  14. Likes Bobw, Silent_Man liked this post
  15. #12
    Apr 2004
    Modesto, CA USA
    6,812
    1136
    Leave it as is and call it "steampunk".
  16. Likes Limy Sami liked this post
  17. #13
    Dec 2014
    Arizona
    369
    39
    62
    Sounds like you need to learn the art of polishing with a air grinder. Use a glue ball, scotch brite flap disc, or cratex.
    You could also nail a piece of scotch brite to a board and drag it. Super easy, It's flat and small. I could finish those in literally 2 minutes with a air grinder, both sides.
  18. #14
    Feb 2005
    9,033
    13782
    10685
    There are a bunch of ways to do it.. The grinding compound didn't seem
    to work very well for me.. I ended up using a wine cork with sand paper
    stuck to it. Worked pretty well.
  19. #15
    Aug 2008
    Californeeeah
    1,485
    48
    315
    A random orbital palm sander gives a nice finish.
  20. Likes jrmach liked this post
  21. #16
    Mar 2009
    4,982
    89
    914
    Quote Originally Posted by Bobw View Post
    The last wine cork I popped was a fake, just plastic. Better upgrade to a more expensive brand.
    I may practice a little with some of the ideas.
  22. Likes Bobw liked this post
  23. #17
    Sep 2002
    People's Republic
    3,003
    216
    2070
    Predrill to save the endmill
    keep the rpms low in case it is 304
    it is so small just a sheet of sandpaper on a backer of some sort, or one of those sponges with sandpaper on it
    try to keep the stokes a straight as possible your eye picks up the little wiggle at the end of the stroke
  24. #18
    Sep 2002
    People's Republic
    3,003
    216
    2070
    BTW I am going to do a similar project, as the faux brushed nickle plastic bathroom vent grill I bought 9 years ago is going green, so this process is actually on my mind
  25. #19
    Apr 2004
    Modesto, CA USA
    6,812
    1136
    Throw it in the street and let a few cars and trucks drive over it. Get it back before someone picks it up and call it steam punk. I read about a antique furniture forger who would throw his work into the ocean to get a beat up wave action on the sand. He also buried it in manure piles to give it the aged yellowed look.
    Bill D
  26. #20
    Mar 2009
    4,982
    89
    914
    I tried a abrasive nylon wire wheel brush. All it did was clean the dust off the surface.
