The Dude
Hot Rolled
- Oct 19, 2010
- Portland, OR
Trying to make an assembly & weld cell that currently uses a rattle-can galvanizing compound. Would like to replace this with a dip tank and blower/heater. This is on the end of what's basically a custom turn-buckle. It has 3/4" all-thread, some nuts tack-welded, a laser-cut 1/4" steel plate at the end (about 2" x 6" long). The whole assembly is around 12" to 18" long (varies) from the end of the 2" tube it's welded to (the tube makes a good dipping handle, doesn't need to be coated). Only this end has to be dipped. Aesthetics aren't important, just can't "gum up" the all-thread.
The current process is cumbersome, wasteful (over-spray) and bad fumes. I'm envisioning that after welding, maybe a minute cooling period, dip the end in a small tank, an air flow to blow off excess and then a heat lamp maybe slight air flow to speed up the drying process.
Any recommendations on a good coating material? Lower viscosity is critical, can't be so thick that it will dry and mess up the adjustment process (about the only good thing on the current process). Doesn't even have to look like cold-galvanized since it's only seen when working inside an enclosed structure.
The Dude
The Dude
