Which aluminum alloy best for bending? Using thin sheet. - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21
    Dec 2004
    uk
    14,053
    4552
    6705
    Quote Originally Posted by welderjosh View Post
    We have done a bunch of tests and 6061-T6 will handle a minimum ISR of 2.5x the material thickness. Any tighter and it cracks, but if you stay bigger then no problem. We have built hundreds of military parts up to 0.125" thick with this as a rule.
    Yeah they might not crack with bending, but put em in a high vibration enviroment and the metal fatique sets in fast. Just because you bent it with out cracking does not make it a good choice for all product applications!!!
  2. #22
    Jul 2019
    INDIA
    Can you answer that 2mm aluminium 3003 h14 temper can bend 90 degree without crack ?
  3. #23
    Jan 2017
    Oregon
    3,166
    639
    2197
    3003 is easily formable.
    The angle does not matter, it's the bend radius that counts.
  4. #24
    Jan 2016
    New York
    246
    6
    65
    2024 is great for machining, not so for forming.
    5052H32 is the best choice for sheet metal forming.
    6061T6 Great for extrusion. Not that great for forming.
    All the best,
    Roger
  5. #25
    Jan 2020
    CHINA
    3003 aluminum sheet In most cases, this is probably the best alloy for bending. You get average strength, very good cold workability and high elongation.
    aluminum sheet 6061 is also bendable. But their bending ability will decrease, however, when you move to T4 and T6 tempers. My recommendation therefore is to bend in T4 condition and then heat treat to T6 if this is possible.
    There is a more detailed information on both aluminum sheet:Is 3003 Aluminum Bendable
  6. #26
    Oct 2007
    SPAIN
    3,815
    2207
    1464
    Quote Originally Posted by rogertoolmaker View Post
    All the best,
    Roger
    +1
    5000 series is no heat treatable - but fantastic for punching/cutting/bending/welding/anodising etc. 5251 is the preferred choice in the UK
    2000 series (2014-T6 UK) is high strength and great for application like pressure manifolds etc and where strong threads are required. No bendy and no weldy!
    6000 series (6082-T6 UK) is medium strength but a great all round for machining and welding but can only be bent with very large rad
  7. #27
    Sep 2010
    Vancouver Canada
    957
    713
    353
    Interestingly, McMaster Carr only has 5052 starting at .032" but they have 2024, 3003 and 6061 at .025. That doesn't mean you can't get 5052 in .025" but McMaster often has the stuff that's industrially common, which can make life easier. 5052 would be my first choice too.
  8. #28
    Jan 2020
    INDIA
    6061-T6 aluminium is tempered and notorious for not bending easily.
  9. #29
    Oct 2005
    16,640
    Quote Originally Posted by dollygao View Post
    Quote Originally Posted by acmi View Post
    Spammers eating off the dead carcass of a long dredged up thread....Excellent !
  10. #30
    May 2014
    Massachusetts
    126
    8
    32
    For bending (w/o cracking) 5052-H32 (or lower strength 3003-H14)!
