Aluminum Mold making tooling suggestion
psandherr
Nov 1, 2016
I am making a 6061 male mold for carbon fiber sleeves. I want it to come out of the cnc lathe with an awesome finish quality to minimize sanding afterwards.
Should i go to brand new HSS, Diamond, uncoated, coated? I have heard many opinions and just wanted everyone else's thoughts?
New aluminum specific carbide inserts, which are rarely coated, but I have never used diamond so maybe that is the best.
Rule of thumb is uncoated on aluminum, honed super sharp. Diamond is for abrasive materials, like any coating it is applied after the tool is sharpened so the edge won't be as sharp.
Now, why 6061? That stuff is like bubble gum. Aluminum injection molds are usually 7075 or one of the proprietary alloys like FORTAL or QC 10.
Dennis
You'll have better results getting your process* dialed in, other than buying expensive diamond/pcd inserts IMO. Also, I think for the exotics to function well they need really high sfm (but I am no expert, hopefully someone will chime in on that).
*proper coolant concentration, finish stock allowance, feed rate/sfm, rigidity, quality material, etc
My issue is i only need to make 1 so I dont have a couple trys to dial it in so i wanted to just start with the "best"
Get rid of the shit 6061 and get 2024
Uncoated carbide tooling
Rough however you want, finish with small stepover, leave 10k for your finish pass
12k or better rpms
Coolant of your choice
12k or better rpms
The program i have is similar to what you say. I'm gonna go with aluminum specific carbide un-coated.
But is the 6061 that bad in your opinion its T-6 if that makes a difference? I havent had issues with it being gummy and i like how it machines compared to 7000 series.
Never used any 2000's
How long are your sleeves, and what's your plan to get them off the mandrel? Are they straight, or tapered? If straight, it's going to require a fair amount of force and 6061 aluminum won't take long to get scuffed by the rubbing. If you're only doing a few it shouldn't matter much, but if you're going to do a lot some kind of steel will be a better choice.
One of my jobs is making wax injection molds. While 6061 will and does work, from a machinability standpoint and finishing 2024 is far superior. When programmed right there is little to no hand work needed. Even fixtures with complex forms come out excellent. We are using stepovers of 2-5k on tools up to .375 for finishing.
Don't know if I've ever heard they like how 6061 machines lol :)
