beckerkumm
Hot Rolled
- Aug 5, 2014
- Wisconsin Rapids WI
I'm replacing the motor on my Smart Brown 1024. The original was an odd size so I made a plate out of 3/4" jig plate for the 100 lb motor to hang from. After threading the 3/8" holes I read that jig plate is probably not the best choice. Should I enlarge the holes and use inserts, bore a recess in the back side for a jam nut to add strength to the existing threads, or none of the above? Thanks, Dave
