matt_isserstedt
- Dec 15, 2003
- suburbs of Ann Arbor, MI, USA
So I am designing some trays for a production kitting setup, have around 30 total to be jobbed out. Nothing exotic, around 6" wide, 2" tall, 8" long, 4 sides. Seems like an easy finger brake job and we have no such capability where I work.
It looks like 3003 and 6061 are commonly available around here looking at Alro catalog. I was going to spec .062/.063" thick material, just not sure if I'm opening myself to cracking problems at the root with 6061 and a typical finger brake sharp bend? I do need to do some light tig welding of other brackets once the trays are completed, that part we can do in-house. I have welded almost all 6061 in my life, not sure if 3003 is going to present any issues?
Aside: I had made the prototypes out of plexiglass but the 2 part epoxy I first used barely stuck and the trays fell apart under testing. I went back with superglue and that was better but sketchy as well. These probably won't get abused but are going to get a lot of cycles. Thinking metal is a much better choice as it will last forever and we can repair it without a new set of chemicals.
Thanks for your thoughts.
