Aluminum surface hardening treatment or coating.
Results 1 to 13 of 13
    May 2012
    Montana
    34
    Default Aluminum surface hardening treatment or coating.
    I am looking for a treatment or coating that can be used on aluminum to increase the surface hardness and reduce friction. The parts can not be anodized.
    Jan 2014
    Chicago
    153
    46
    53
    Have you looked at Cerakote?
    May 2012
    Montana
    34
    Yes, but it really wont reduce the friction like I would like. Anodize would be ideal, but the parts have steel inserts that cant be removed
    Jun 2012
    Michigan
    4,973
    4532
    2997
    Quote Originally Posted by AlexW View Post
    Can the inserts be masked off prior to annodize?
  5. Likes Porschefix, gkoenig liked this post
    Nov 2004
    Webster Groves, MO
    7,464
    1899
    3482
    There are various coating methods such as vacuum evaporation and sputtering that can apply many different coatings. Look at the coatings for milling cutters, etc. Astronomical mirrors are usually glass that is aluminized, then coated with silicon monoxide. I have some thin film books I can look at.
    Bill
    May 2005
    AZ
    2,371
    221
    806
    Just for future consideration, to state the obvious, if you can anodize before installing inserts, that works nicely.
    Jul 2012
    Washington
    3,008
    1182
    1251
    This caught my eye awhile ago Tuffcoat - Quality Coatings. I don't know if your steel inserts will be an issue but it may be worth a call.
  9. #8
    Nov 2011
    Missouri, USA
    2,124
    1354
    2723
    If this is a one-time thing because you installed the inserts before realizing it needed a hardening process... you CAN mask them prior to anodizing. We found ourselves in a similar boat when we didn't see the line buried in the specs regarding anodizing. We had some steel bushings pressed into some ears that had a critical in-line function and didn't want to risk pressing them out and back in.
    Long story short, we found out masking works and didn't hurt the bushings. Our anodizers had some sort of goop the said they plug holes with and put some around the faces of the bushings too. Came out nicely, and the bushings checked well against a Deltronic set, to make sure they didn't grow any.
  10. #9
    Nov 2014
    206
    132
    115
    Quote Originally Posted by DavidScott View Post
    Tuffcoat is hard anodize filled with Teflon, so it's not possible if you can't do anodizing. Per the description in MIL-A-63576A: "This specification covers the requirements for an electrochemical process for building a lubricative anodic coating on aluminum and aluminum alloys. The unsealed anodic coating is impregnated with polytetrafluoroethylene (PTFE) or coated with a resin-bonded materials containing PTFE"
  11. #10
    Jan 2014
    Temecula, Ca
    3,055
    1337
    3972
    How 'bout electroless nickel w/ Teflon?
  12. #11
    May 2009
    Canandaigua, NY, USA
    2,932
    144
    1325
    This stuff is low friction, resin based and quite durable. They have several flavors and can do small runs to test.
  13. #12
    Dec 2018
    SRI LANKA
    I am also looking for a surface hardening treatment for our aluminum welding bars. It should with stand temperatures up to 350deg and reduce also the friction. As well I am looking for a material that has a Good heat transfer and is not deforming under 350deg. I was thinking of aluminum, copper or brass aloy
  14. #13
    Oct 2004
    UNITED KINGDOM
    1,415
    91
    538
    Nikasil might have some of the proprties you are looking for, although it is quite a specialised process. Pioneered by Mahle mainly for cylinders so Aluminium pistons can run directly in Aluminium cylinders. Widely used for motorcycles.
