Aluminum - When will -H32 be better than -H38
Likes Likes:  0
Results 1 to 4 of 4
    Sep 2018
    VIET NAM
    8
    Default Aluminum - When will -H32 be better than -H38
    Hi,
    Im new using Aluminum and need some advice.
    We will laser-cut 5052 aluminum sheet-metal parts and bend simple shapes and TIG-weld all together for marine use.
    I have checked prices on 5052 with different tempers and prices are the same. So why not using highest H38 temper all the time to ensure best possible yield and ultimate strength? Any drawbacks with using higher temper? Easier to crack when bending?
    Thankful for some advice.
    Zazz
    Jan 2016
    New York
    258
    6
    69
    The difference is the hardness of the material. If you are forming the parts and welding; 5052H32 is the material of choice.
    Roger
    Mar 2012
    Geilenkirchen, Germany
    2,564
    1511
    1310
    I don't think it makes any difference anyway, as the heat treat is lost after welding.
    Oct 2010
    Oregon
    5,311
    4802
    1952
    It makes a difference when bending/forming before the welding.
