Hi everybody,
Been a long time since I've been here. I recently picked up an non-working Ammco 2002 computer control brake lathe for a can't go wrong price. Problem is in the control box - it will jog both the spindle and feed but the spindle won't turn and the cross and spindle feeds don't work. The main motor does work - it turns fine when dc voltage was applied. Also, the wiring diagram in the manual I picked up does not match the lathe I have. I'm thinking there was more than one version, but I wouldn't bet much money on it. If mine was messed with, it looks factory. I was wondering if by some very slim chance someone may have a working replacement part for the lathe or know someone who works on them.
I was thinking a more likely scenario would be to ditch the existing control setup and use new or used DC motor controllers. Any insights on making up such a setup and where to buy the controllers? I don't want to spend too much because it may not take too long before just getting an Ammco 4000 will make more sense money-wise. I've been told they can be had pretty cheap if I look in the right places.
Thanks a lot, Wade
Thanks a lot, Wade
