Sierevello1
- Nov 16, 2009
- Indianapolis, IN
Hello,
I have an Anilam Crusader M 3-axis will and went to use it this afternoon and ran into a problem.
I haven't used the mill in several months but it was working fine when I used it last.
I went to upload a program from the computer to the control and the control just sat there and did nothing. It worked fine last time I used it.
I re-checked everything in the software and made sure all settings matched and still no luck. I checked the cable and it is good. I also reset the memory on the control and re-entered all of the RS-232 settings.
I used a jumper test on pin 2&3 and pin 6&20 and got a UART fail message. I then ran the onboard diagnostics and it gave me a DUART fail.
The funny thing is that it will download from the control to the computer using RS-232 and give me the proper AUX0 code after it does it.
I am not sure what board contains the UART?
Any help greatly appreciated.
Steve
Steve
