03-01-2021, 11:11 AM #21
Yes, I am going to make things for myself. In the past I made chocolate chip cookies and warmed a pizza. All this started when I
could not locate a store that had a Boboli pizza dough round in a plastic package. Even the ones at Target are thinner than cardboard.
So that was the turning point. I know that a frozen pizza exists but I have turned away from packaged frozen stuff. Probably because I resent
the fact that executives and investors in a food packaging company are putting me at risk when I buy their products.
I bought the bowl lift Aqua Blue model. Not opened it yet. I'm trying to get used to the color which I thought was ugly at first. I once said
on this forum that some ugly girls start to look better once you get to know them. And that some pretty girls start to look ugly when you get to know them.
Is Aqua Blue ugly? Or just a modern type color that I know nothing about?
03-01-2021, 11:12 AM #22
F**ks sake! You are a MAMMAL! Butter is good for you. Helps you regulate fats and oils metabolic rate and stay fit, slender, and healthier! Your immune system appreciates it.
Guess which Provost-Marshall's MP's whack a cancerous cell?
Got it in one. A healty immune system has that job.
So long as you see to it the raw materials to make its ammunition with are available. And not synthetic sweeteners and foods we weren't MEANT to have in huge surplus. As folk lived and ate in leaner times.. before cancer became such a self-imposed scourge, anyway.
2 lb box of demerara sugar is down to about 20 percent. It was opened April of 2020. Salt is for cleaning fresh veg. I don't EAT of it!
Start avoiding butter and milk with "margerine", "skim milk" "2% low", soya, almond, oat milk?
WTF do you think happens?
A signal is missing.
Your body goes "Oh SHIT! Tough TIMES are here!" Goes into overdrive MAKING fats and oils, storing them up for an emergency that is not THERE?
And then you become a jelly-belly lard-ass off your own chemical factory producing what it has no customer for!
Part of how I lost those 60 M-F lbs from 245 or so down to 180-185?
Whole milk or even "half and half", all the butter I FEEL like, cooking especially.. because you won't actually over-do it .. unless deprived OF it.
I did say "mammal" ?
Weird thing is if you don't get yer butter? MEN grow big floppy tits!
03-01-2021, 11:26 AM #23
03-01-2021, 12:06 PM #24
I wonder how many are in lab's and industrial settings ?
I know of one shop mixing up small batches of silicone, they use it just about every day.
03-01-2021, 12:30 PM #25
I started making smoked kilbasa a while back as I couldn’t find any good sausage the wasn’t loaded with salt. To get started I bought a cheap electric grinder off eBay for $30 and made a hydro-stuffer. Ended up giving the equipment to my nephew as he would probably use it more. I subsequently bought another grinder of the same make as it held up quite well. Unfortunately I didn’t check it out when it arrived and six months later discovered it was damaged. Fixed it and it died after 20lbs of sausage. The grinder part is actually rather well built and I looked at the KitchenAid attachments and wasn’t impressed. So I modified the hub attachment area and made a tapered adapter so it will fit the KitchenAid.
03-01-2021, 01:14 PM #26
03-01-2021, 01:26 PM #27
Gave one to my girlfriend 40 years ago. She's now my wife and she still makes our own bread. Still running without any repairs needed.
03-01-2021, 03:11 PM #28
Of course since I made the modification you can buy aftermarket grinder attachments that will fit. They will come with all the goodies for around $40. The grinder I used uses the #5 plates which is larger than the KitchenAid brand. Don’t think I’d push it past the #5 size. Had those other attachments been available at the time I’m sure I still would have made my adapter.
03-01-2021, 03:32 PM #29
I have done some reading of the reviews on the tilt-heads. Lack of power when mixing something thick.
I got a rigid head machine and its sitting in a box as I try to get accustomed to the blue-aqua color.
The tilt head's weight is what keeps it in position.
Although it is heavy there may by vibrations at certain resonant frequencies that make the head vibrate.
Possibly like a mix moving from a rough state to a smooth state. I don't know if this is actually true.
But it gives me a reason to blow more money on a machine with a rigid head and higher HP motor.
I think a damping action like the weight of a hand would make that problem go away.
On a BP operation sometimes a 2x4 piece of wood helps dampen out vibrations and noise when held on a work piece.
03-01-2021, 06:57 PM #30
03-02-2021, 12:04 AM #31
03-02-2021, 10:15 AM #32
I think you should "go industrial"....
Reciprocating Continuous Kneaders - Tri-Kneader Mixer | B&P Littleford
03-02-2021, 05:12 PM #33
The reasons for posting this topic:
1. I like the machines and did not appreciate them until recently. Especially trying to whip something by hand.
2. I was aware of a behavior alteration program regarding the need to reach out for food. If an excess inventory is available the individual may feel a comfort
zone and not stuff his/her pie hole.
3. The increase in popularity for making goods might fit in with the behavior alteration program. The excess inventory is now more base products like flour, sugar.
So now the individual is one more step removed from a cookie or piece of cake. It has to be made first. Now more planning takes place.
4. Side benefits, less GMO's , more organics...
5. I recently bought excess supplies and the need for gratification has diminished. Works for me, maybe this idea can help somebody else.
03-20-2021, 06:08 PM #34
03-20-2021, 06:22 PM #35
tdmidget liked this post
03-21-2021, 06:27 AM #36
LOL KitchenAid mixers have been around for MANY years. My aunt told me she'd worn out 3 of them. (She baked a lot!)
We own a bowl lift model. I got mine cheap because the vertical adjust range wasn't big enough and the tools didn't come close enough to the bowl. I solved that by putting a couple of stainless washers over the bowl retaining pins, essentially shimming up the bowl. I've been using it that way for at least 15 years now, works great.
KitchenAid mixers are like Norwegian sweaters. One per relationship.
metalmagpie
03-21-2021, 06:48 AM #37
Cough up the $$$ for a Hobart N-50 (used for if you can find one) and never look back...
03-21-2021, 08:11 AM #38
03-21-2021, 10:35 AM #39
I returned the aqua sky color unit. Couldn't live with it.
The bowl issue I see with these units: The bowl is placed on the two pins and pushed down in the back, the bowl rotates and locks into the retaining clip.
Then they install the wire whisk. The problem is that shipping makes the whisk rotate off the spindle and the bowl unlocks from the clip. Then for how many
shipping hours the stuff is banging around.
The warranty for 1 year is good. Any problem and just notify Kitchen Aid. They arrange and pay for shipping the bad unit to them, and a replacement to you.
03-21-2021, 01:05 PM #40
My only experience with mixers was my Aunties old Kenwood Chef. Made a new internal gear ring,with nylon pinion for driving the whip. Once put back together,and switch it on-there was a big blue flash and a loud bang! What a reward,didn't know whether Or
