So I got a BT30 spindle of the import kind similar to this:
ATC spindle BT30 Spindle CNC Milling Rounter Electric Spindle Motor 220V with Belt for BT30 Spring + Drawbar|motor 220v|220v motor|220v electric motor - AliExpress
The bearings were OK. But I desired to upgrade. So I go some matched angular contact bearings to replace the radial grooves it came with.
There are a set of 3 toward the spindle nose and a pair towards the rear.
I'm mostly asking about the rear bearings. The front bearings run true and everything is great. I didn't have the forethought to realize the rear bearings have no form of preload. The inner races butt against a shoulder on the shaft, but the outer races have no shoulder. There is a rear plate that bolts on, but is nearly 50 thou away. The bearings I used are a match pair of tandem (facing the same direction).
So my question is: do I need to make a shim to add some preload? My father (a retired mechanic, who is a smart guy) seems to think they will be fine to run free. I am wondering if the outer race will float away from the inner race.
Now I'm not so sure I should have left radial groove bearings as the rear pair.
I attached a cross section of the spindle someone else made. Be advised, there are threads and nuts to compress both sets of inner races.
Would welcome any thoughts on the subject.
