Larger or smaller? Why not one that is specifically scaled for your lathe?
Why not one that gives you THE fastest tool holder change?
Why not one that provides the ultimate rigidity?
Rock solid stability: the post is solid steel with only a central hole for the mounting stud.
And the tool holders wrap around the post with a very large area of contact: the post and tool holder are like one, solid piece of steel. The central stud places the post in compression for extra stability.
Excellent repeatability: There is a large flat on the post and a height adjustment screw that provide repeat positioning that is well better than 0.001" in all three axis.
Fast, One Hand Tool Change: This design offers a very fast tool change. A tool holder can be removed with ONE hand, NO TOOLS, and using ONE continuous motion. The installation of the new tool holder is equally fast and easy, again with no tools and ONE continuous motion. Quick tool changes are the essential idea behind a QCTP and this design offers the fastest possible tool change.
Independent Adjustments: Tool height, angle, position, all adjustments are independent of each other to the maximum extent possible.
No Dovetail: The dovetail of many tool posts offers a very small area of contact between the post and the tool holder. This can have negative effects on the positional accuracy, repeatability, and rigidity. And it is harder to make. This design offers an easy to machine, round post with a generous flat for accurate positioning and rock solid rigidity.
Self Cleaning: There is virtually no place for chips or other debris to hide. The action of installing a tool holder wipes the mating surfaces clean. And if you insist on cleaning them, those surfaces are readily accessible so cleaning is a matter of a fast wipe. There are no hard to reach corners.
Easily Scaleable: The drawings are scaled for a SB-9 but can be easily scaled up or down for almost any size lathe.
Here are several ways to obtain the article with photos and drawings:
Original Article:
Quick-change Tool Post, Feb-Mar 2010 Machinist's Workshop
Back Issues << Machinist's Workshop << Metalworking << Storefront << Village Press
Free Download of later version:
Dropbox - QCToolPostRc.doc - Simplify your life
Latest version:
Quick Change Tool Post for Lathe - HomemadeTools.net
