Marty Feldman
Titanium
- Feb 21, 2005
- Falmouth, Maine
Anti-seize compounds (Never-Seeze, e.g.) commonly contain graphite. Is it just graphite-based lubrication that is responsible for what these products do? One source says that the key to their easy-removal action is making the initial tightening require less torque to achieve the same lock-in. Another possibility is that it is the metals in these compounds, like steel, copper, et al., that provide gritty spacing between the male and female threads, lessening friction from metal to metal contact area when removing. Something more sophisticated having to do with chemistry?
I use this stuff effectively on things like automobile wheel lugs, but I am curious to know if it might be of use on small shop bolts. Two in particular, on mill tooling, that I always have major trouble backing out after use are the central retaining bolt for an annular cutter arbor and the hex-socket central retaining bolt for slitting saw blades. I should add that in both these cases the tooling is of midrange quality, not Harbor Freight but not highest quality either.
-Marty-
-Marty-
