Anti vibration coupler
Page 1 of 3 123 LastLast
Results 1 to 20 of 43
    Jun 2019
    CANADA
    British Columbia
    79
    36
    8
    Default Anti vibration coupler
    I am trying to reduce the vibration in an old McDougall lathe. Long ago it was converted from belt drive to direct drive. The motor is mounted vertically in the base under the headstock and connected to the input shaft with something similar to
    McMaster-Carr
    There is some misalignment, which can be reduced, but wondering if there is a different style coupler on the market that will tolerate some misalignment and hopefully reduce vibration. After the original modification was done, the motor was replaced with a larger one. The size of the motor and the way it is mounted make it very difficult to line up the motor perfectly. Any suggestions would be appreciated.
    Feb 2001
    Redwood City, CA USA
    5,351
    252
    1208
    That coupling already has a rubber center and provides significant damping and misalignment capability compared to a lot of other couplings. What is the evidence that the coupling is the problem? Is it possible some shaft is just plain bent? Is some sheave wildly out of balance?
  3. Likes Cyborg liked this post
    Jun 2019
    CANADA
    British Columbia
    79
    36
    8
    It’s a little awkward getting in there with dial gauges, but I checked the runout on the motor shaft and it’s ok, same with the lower half (drive side)of the coupler. When I checked the upper half (driven) of the coupler it seemed to be out by a total of approximately.014”. I marked the high spot with the idea of moving the motor over .007, but I noticed that when rotating the coupler about 25 degrees it dropped to zero. That suggests something is wonky with the upper half. I could just forget about the runout on the upper half of the coupler for now and run the indicator off the shaft and adjust the motor mount based on that. Only thing is, adjusting the motor will probably send me off the deep end, so thinking maybe a new, better? coupler before I start.
    As a crude test, you can put a piece of stock up against the lower half while it’s running and there is no noticeable runout. Put the piece of stock against the upper half or the input shaft and the piece of stock bounces around quite a bit.
    If I was machining parts to look like corncobs it wouldn’t matter. The vibration telegraphs through the cutting tool. The alignment is definitely out, but the coupler is suspect as well.
    Not sure what you mean by sheave. There are no pulleys. From the coupler, the shaft goes up to the headstock and direction is changed via a crown and pinion differential that was borrowed from a VW. From there it goes through a VW 4 spd synco gearbox. Strange, but true….
    Feb 2007
    St. George, Utah
    1,432
    956
    1001
    How much horsepower are you working with?
  6. Likes Cyborg liked this post
  7. #5
    Sep 2004
    Wisconsin
    276
    75
    That type of coupler is commonly used on drives up to about 75 hp. They do not require the precision of a dial indicator alignment. All that's needed is a straight edge and feeler gauges. If you want more precision you still start with straight edge and feeler gauges in order for your indicator reading to start close to where it should be. There is a procedure for taking face and rim indicator readings and then calculating shim amounts to bring shafts into proper alignment. Either method is difficult in tight quarters. Belt drive would lower vibration and alignment problem.
  8. Likes Cyborg liked this post
  9. #6
    Feb 2009
    Oz
    397
    19
    85
    Remove / disconnect the coupling and see if the motor is out of balance
  10. Likes Cyborg liked this post
  11. #7
    Feb 2010
    ch
    3,383
    280
    472
    yes, find the source of vibration before trying to dampen it.
  12. Likes Cyborg, Scottl liked this post
  13. #8
    Dec 2012
    AUSTRALIA
    4,852
    29
    1751
    Ya but...you havent read the part where the drive includes half a Volkswagen.....a lot of scope for vibration/misalignment there .......incidentally,VW wheel drive is via a sort of a CV joint ,and the diff would need to be locked up somehow,too.
  14. Likes Cyborg, Scottl liked this post
  15. #9
    Mar 2012
    Geilenkirchen, Germany
    2,924
    1634
    1534
    I suggest the OP get a real lathe.
  16. Likes Cyborg liked this post
  17. #10
    Jun 2019
    CANADA
    British Columbia
    79
    36
    8
    Quote Originally Posted by steve-l View Post
    Excellent suggestion. It’s crossed my mind a few times. The lathe was cheap and just the tool post, chucks, and portable milling machine that came with it more than justify the cost. There are a few issues with the lathe which may be worth fixing if I can sort out the vibration. I have another smaller lathe and basically bought this one because of its ability to remove metal quickly.
  18. #11
    Jun 2019
    CANADA
    British Columbia
    79
    36
    8
    Quote Originally Posted by technocrat View Post
    I’ll do that at some point, but from what I’ve seen so far, it doesn’t look like the problem is the motor itself. Other than it’s single phase.
  19. #12
    Jun 2019
    CANADA
    British Columbia
    79
    36
    8
    Quote Originally Posted by john.k View Post
    There is just the crown and pinion…. no spider gears. I actually wondered about a CV joint, but they can cause vibration problems too. Maybe I’m fooling myself, but looking for a relatively easy fix. If it gets too involved then I’m better off taking Steve’s advice.
  20. #13
    Jun 2019
    CANADA
    British Columbia
    79
    36
    8
    Quote Originally Posted by Gordon Heaton View Post
    Good question. I don’t know. The motor is squeezed in there and even with a bore scope or mirror, I can’t see the plate. It runs off 220 and came with some fairly hefty cable. Running off a 30 amp breaker which works. Bride claims the lights upstairs dim when I switch it on. Assuming it is either 5 or 7.5 hp.
  21. #14
    Jun 2019
    CANADA
    British Columbia
    79
    36
    8
    Quote Originally Posted by deltap View Post
    Belt drive has also crossed my mind, but again, not a lot of real estate in there. Without relocating the motor somewhere else, I’d be limited to about 6” between centres on the shafts. Relocation of the motor might be the second best option.
  22. #15
    Jun 2019
    CANADA
    British Columbia
    79
    36
    8
    I know this thing sounds strange and it is. The modifications were done long ago, presumably because of budget constraints. Although you could question the logic, the original modifications were well done. For example, the bearing in the headstock (assuming it was babbitt) was replaced with a pair of taper rollers and it’s still pretty much perfect. I’m only guessing, but I think the vibration problem arose either when a subsequent owner installed the larger motor or one of its moves resulted in some damage. The later is a distinct possibility. I can’t ask the fellow who installed the motor because he’s no longer with us.
  23. #16
    Apr 2018
    9,252
    4485
    I'm having a hard time picturing this thing But normally an automotive ring and pinion is optimized for the pinion to drive the ring gear in the forward direction. If it's driving backwards from that, with the ring driving the pinion ? Or even normally but with the pinion going the wrong direction ? I'd expect it to be extra noisy and rough. The teeth are now pessimized for that direction.
  24. Likes Cyborg liked this post
  25. #17
    Jun 2019
    CANADA
    British Columbia
    79
    36
    8
    Quote Originally Posted by EmanuelGoldstein View Post
    Thing? Thing of beauty maybe. The crown and pinion seems quite happy and it turns in the correct direction… at least when the lathe is in forward. I’d wager a bunch of beer it’s a combination of the natural tendency of a single phase motor to vibrate, misalignment of the motor, and the coupler itself. The world must have a better coupler somewhere. Along with the lack of space, the setup for adjusting the motor is a bit of challenge, so if there is a better coupler then it would be nice to install it first.
    Hard to make out, but gearshift lever sticking out the top is for the back gear High/Low range.
  26. #18
    Feb 2007
    St. George, Utah
    1,432
    956
    1001
    Quote Originally Posted by Cyborg View Post
    . . .Hard to make out, but gearshift lever sticking out the top is for the back gear High/Low range.
    Turned the lights on for ya:
  27. Likes Cyborg, sfriedberg, michiganbuck liked this post
  28. #19
    Jun 2019
    CANADA
    British Columbia
    79
    36
    8
    Like it’s owner…. looks better in the dark.
  29. Likes Gordon Heaton liked this post
  30. #20
    Aug 2005
    Tucson AZ
    6,778
    10956
    3255
    Would be fine for a 75 hp manure spreader if you don't care about bearing life and such. On a machine tool that misalignment will show up as the OP has learned. It will also reduce the life of bearings and associated parts.any coupling that far out will transmit some pulse as it rotates. There must be a better way than half of a VW packed in there.
