stephen thomas
- Jun 3, 2001
I've already posted versions of this Q on a couple marque-specific and homebuilt sites.
Surprisingly no one has stepped up to report actual experience or insightful comments.
Will try the Van's forum, and also check with EAA & perhaps AOPA.
Nonehtelss, PM has such depth of experience and range of interests including other homebuilders, FAA guys and A & P's, so here goes:
A couple years ago i bought an amateur built Sonerai 2L in Canada.
Hence, the airworthiness certificate is surrendered before in crosses the border.
Typically, in the USA, an Experimental-amateur built ("E-AB") airworthiness certificate ("AWC"), once gained, will transfer with the airplane. No new AWC required, no new flight tests except as required by the maintenance or mechanical changes if any, etc. However, an import that changes ownership loses the foreign AWC and must gain one in the US after it crosses the border, including the 40 hrs fly-off in designated local area.
All fine and good.
However, as a pre-built airplane, there seems to be a tendency for the FAA to want to position it in the Experimental - Exhibition category, not Amateur Built as would be correct if US original build. I am well aware that there has been significant erosion in the E-Ex category over the years and it is nowhere near as restrictive as it was some years ago. Nonetheless, I'd certainly prefer E-AB.
Anyone done it?
How best to prep my case before meeting FSDO rep in the next month or so?
I'm doing some work on the airplane to make the lid fit me , already reserved N# a couple yrs ago. Fine with DAR inspection, flying off the hours, etc.
The question here is "How best to direct entire process to E-AB AWC" result?
Thanks for any insights.
smt
All fine and good.
Anyone done it?
smt
