motion guru
- Dec 8, 2003
- Yacolt, WA
I bought an older JLG boom lift and went through it mechanically and got it running really well. It is a 1999 model but the motor data plate says 2007 and the hour meter has 3200 hours.
The "Creep" speed setting doesn't work for the boom rotate . . . as in, it doesn't rotate at all. It rotates fine at the normal speed but when you are 40 feet up in the air next to a window it's kinda nice to take it slow and easy.
The wheel speed and raise/lower each work at nice controllable reduced speed when I turn the creep speed switch on, but the boom rotate stops working all together. Where do I start looking to fix this?
