Any sources for coarse 1/4" thread other than 1/4-20?
Page 1 of 3 123 LastLast
Results 1 to 20 of 51
    May 2007
    Champlain, NY
    51
    31
    Default Any sources for coarse 1/4" thread other than 1/4-20?
    Considering a project that will require a stationary part to move left and right from center with less than one revolution of the screw head. Just tried 1/4-20 but it only travels about 80% of the travel needed, any ideas for a screw and tap source?
    Jun 2012
    Eastern PA
    987
    274
    448
    Why not use a 3/8-16 screw?
    Or, Roton has 1/4-16 Acme threads and nuts:
    1/4 - 16 Right Hand Acme Lead Screws & Nuts for Power Transmission - Roton Products, Inc.
  3. Likes Zip, metalmagpie liked this post
    Oct 2005
    16,086
    Quote Originally Posted by Zip View Post
    WoW.....let's put some real numbers here..."About 80%"...
    What travel doo you want, for each revolution of the leadscrew ?
    Sep 2007
    Washington
    5,274
    201
    1601
    Or, have someone make a thread with whatever pitch you want, just be mindful of how weak it becomes when the minor diameter gets smaller and smaller.
    Regards.
    Mike
    Last edited by Finegrain; 11-24-2019 at 12:34 PM. Reason: Previous reply already talked about Acme
    Oct 2019
    CANADA
    British Columbia
    63
    109
    22
    A 1/4-20 thread travels .050” in a full revolution.
    The OP needs to tell us the distance required then figure out the fraction from there.
    20 TPI = 1/20 = .050”
    If my math is right and 20 TPI is 80% of the travel then 16 TPI is 100% of the travel. Or very close at .0625”
  7. Likes Gordon B. Clarke, James H Clark liked this post
  8. #6
    May 2010
    DENMARK
    3,511
    4045
    12642
    Quote Originally Posted by Finegrain View Post
    Acme ...
    McMaster-Carr
    Regards.
    Mike
    As DavidR8 points out if 20 TPI gives 80% then 16 TPI gives 100%. Anything courser than 16 TPI will give more than 100%.
    Re "... whatever pitch you want, just be mindful of how weak it becomes when the minor diameter gets smaller and smaller." (unless I misunderstand you) a finer thread is not only stronger but is better at withstanding vibration.
    1/4-20 is UNC. If you want less than 20 TPI (for example 16 TPI) you'll have to go up in diameter. Post #2 might be a solution.
  9. Likes DavidR8 liked this post
  10. #7
    Sep 2007
    Washington
    5,274
    201
    1601
    Quote Originally Posted by Gordon B. Clarke View Post
    I think you do . Larger pitch, e.g. 16 instead of 20 >> smaller minor >> weaker fastener.
    Regards.
    Mike
  11. Likes Gordon B. Clarke liked this post
  12. #8
    Jan 2007
    Norfolk, UK
    19,054
    14557
    14660
    1/4 x 16 tap 1/4-16 Special Pitch Plug Tap, High Speed Steel all for $8.90
    '' die 1/4-16 Special Pitch Round Die, 1" Outside Diameter - High Speed Steel '' $11.50
    Home & dry for under 21 bucks HAS to be a deal
  13. Likes DavidR8, Zip, Bobw, michiganbuck liked this post
  14. #9
    May 2007
    Champlain, NY
    51
    31
    Quote Originally Posted by Limy Sami View Post
    Thanks all....this is what I was looking for!
  15. Likes Limy Sami liked this post
  16. #10
    May 2010
    DENMARK
    3,511
    4045
    12642
    When you're right, you're right. Must admit I was surprised that it existed.
  17. Likes swarfless, tdmidget liked this post
  18. #11
    Oct 2007
    SPAIN
    3,664
    2080
    1370
    C'mon, you can tell me.
    If this was in the new format Metrology forum, you'd have deleted your own post because it was non metrology related.
    So why do you feel it is right to post verbage here that adds no content?
  19. #12
    Oct 2007
    SPAIN
    3,664
    2080
    1370
    Don't get me wrong, i have no problem with a comment like you have made, but you have already stated that it's unacceptable and will be deleted in *your* forum?
    To me, comments (like you posted) are acceptable - a forum is "just like talking". Discussion if you will.
  20. #13
    Nov 2003
    5,119
    182
    1622
    As others have said, 1/4-16 gives you exactly 100%, calculating from your 80% and 1/4-20 numbers. But that is an EXACT number, not an "about" number which may wind up being on the shy side of what you need.
    If 1/4-16 is exactly what you want, then just search for that. Here's one:
    https://www.mscdirect.com/product/details/01205749
  21. #14
    May 2019
    574
    148
    222
    I'm surprised no one has mentioned a two start 16 pitch, giving you 16 pitch but the strength of 32 pitch. Play with whatever numbers you want. Make you own tap or have one made, screw is pretty easy to cut on a lathe.
  22. Likes swarfless, Derek Smalls liked this post
  23. #15
    Jan 2007
    Norfolk, UK
    19,054
    14557
    14660
    Quote Originally Posted by Hardplates View Post
    Some double lead taps off the shelf here Regal Cutting Tools
  24. Likes barbter, swarfless liked this post
  25. #16
    Mar 2011
    Geneva Illinois USA
    6,278
    2716
    2425
    Double, triple and quadruple threads are not something that most people know about.
    Tom
  26. #17
    May 2019
    574
    148
    222
    Quote Originally Posted by TDegenhart View Post
    Tom
    This is a manufacturing and machining forum....no? Even a milk jug has multi start threads
  27. Likes barbter, Bobw, tdmidget liked this post
  28. #18
    May 2011
    New Jersey
    2,425
    213
    1305
    Tom
    I e never seen one in person, I'd love to get my hands on one just to check it out.
  29. #19
    Jun 2012
    Idaho
    3,154
    1736
    2052
    Quote Originally Posted by plastikdreams View Post
    make one,,good exercise on lathe use
  30. Likes TDegenhart, Derek Smalls liked this post
  31. #20
    May 2011
    New Jersey
    2,425
    213
    1305
    Quote Originally Posted by jrmach View Post
    It's a good idea...maybe some day
