Any true inch benchtop lathes available? (must be under 350 pounds) - Page 5
Page 5 of 7 FirstFirst ... 34567 LastLast
Results 81 to 100 of 139
  1. #81
    Jun 2012
    Michigan
    14,336
    4885
    5182
    Quote Originally Posted by lucky7 View Post
    I find it easier to swivel the top slide a couple of degrees off 90 if I'm trying to catch a tenth.
    Did part of my training on Standard Modern 13"ers. Liked em!
    L7
    So yes, decent machine and operator skills made close size possible.
  2. #82
    Oct 2005
    CANADA
    Ontario
    1,720
    576
    672
    Quote Originally Posted by bob View Post
    Not to be a jerk but what you did here is not what you claimed to be able to do
    Bob
    No offence taken. How so?
    "With a little trial and error it was easier to take a few tenths cut to get there but if needed I could take a tenth out."
    Not wanting to jack the OP's thread or blow my own horn but just wanted to tout the accuracy of some of the Emco machines.
  3. #83
    Nov 2013
    Eastern Massachusetts, USA
    7,783
    6479
    6894
    I have to ask,; is the requirement corporate/work or hobby related?
    The reason I ask that is because within your constraints the best fit for hobby use with a max 30k budget would be a late model Super 11. They are slightly over your weight limit at about 375 pounds without stand but that's only 25 pounds over.
    They are not still made and thus no factory support but there are many out there in excellent shape and since the chuck mount is an industry standard, chucks are easy to source although items like steady rests might take some searching.
    If for some reason you MUST have a currently produced lathe I would say drop the inch requirement and get a metric Wabeco fitted with a DRO.
  4. #84
    Jul 2006
    Australia (Hobart)
    4,105
    652
    3297
    Quote Originally Posted by Terry Keeley View Post
    Some here may scoff at this but I can reliably take a tenth out of a bore in aluminum with my S11, Iscar inserts and a good dial indicator on the cross slide (50 millionths cut).
    I believe it. Mine is also a much more accurate machine than I expected. I still prefer the Chipmaster for its rigidity and (IMO) better ergonomics but the Maximat 11 is a gem of a machine. I machine quite a bit of 316 on mine.
    PDW
  5. Likes Terry Keeley, dcsipo liked this post
  6. #85
    Jul 2007
    UNITED KINGDOM
    5,527
    3493
    2870
    Still made. RDG in Mytholmroyd bought the rights and most of the parts when the Beeston factory was closed:-
    Myford Ltd Home Page (British Engineering at its best)
  7. Likes Nmbmxer liked this post
  8. #86
    Jul 2006
    Australia (Hobart)
    4,105
    652
    3297
    Quote Originally Posted by Mark Rand View Post
    Comparing a Myford to a Maximat 11 - well, no.
    The only bit is, they're both lathes and nicely built.
    Functionally, hell no, a Myford is a small feeble machine. In a choice between a Maximat and a Myford, I'd take the Maximat in a heartbeat.
    PDW
    PDW
  9. Likes Terry Keeley liked this post
  10. #87
    Oct 2015
    AUSTRALIA
    146
    46
    A v10p is the emco equivalent to a myford and it is a miserable piece of crap. And 11 is a different thing altogether. V10 has plain milled cross slide ways and is chintzy
    Sent from my SM-G973F using Tapatalk
  11. Likes Mark Rand, Terry Keeley liked this post
  12. #88
    Jul 2006
    Australia (Hobart)
    4,105
    652
    3297
    Quote Originally Posted by rblalexander View Post
    More like an Emco Compact 8 and a Myford IMO. About the same swing and rigidity.
    For those who don't know, the Compact 8 was the basis for all those shitty Asian 8x18 lathe shaped objects. And the original was nothing to get excited over. My FIL has one. He really should have known better.
    PDW
  13. Likes Terry Keeley liked this post
  14. #89
    May 2010
    Cambridge, MA
    1,871
    83
    1093
    Concerning the Maximat, etc, I really would prefer a new lathe that is supported by the manufacturer. I don't want to get into a restoration job or have to start scouring eBay for accessories.
    Concerning the Schaublin, I think they only come in metric.
    I do not want an 11" swing / 1500 lb lathe for this use. I already have access to lathes of this class and do not need another. I want an 7-8" lathe in the range of 300-500 pounds. The bench where this is going is too small to comfortably fit an 11" lathe, and the lathe is probably going to have to be moved at least once, maybe twice in the next couple of years, and frankly I don't want to have to figure out how to move a 1500 lb object multiple times into and out of a tight space. This is a SMALL PARTS lathe.
    The WABECO rep said that they are no longer making the imperial version and that I should just get the DRO if I want to do imperial--something I am not enthusiastic about. However, it may be moot because they are not even taking orders right now due to supply chain problems.
    One option is that I get a chucker lathe, which would be a compromise, but there are some advantages too, so maybe that is the way to go.
  15. #90
    Feb 2004
    peekskill, NY
    27,571
    6472
    Please clear something up: do you need lead screw threading on this machine?
    If not then a small bench lathe in the 7-8 inch size would do the job, like one of these. Just be sure to get an inch compound slide. First lathe below is an 8" swing machine, takes 4C collets. Second one is 7" swing, takes 3C collets. Both are inch-type compound slides. Both under 300 pounds and neither are supported by the manufacturers now. =)
    But you could have your pick of top flight machines like this for your price range.
  16. #91
    Jun 2012
    Michigan
    14,336
    4885
    5182
    Quote Originally Posted by jim rozen View Post
    One could make a draw screw attachment for that pratt. One screw for each imperial and each metric pitch and turn that fine lathe into a thread cutting machine.
    and one can die-cut threads on the pratt.
  17. #92
    Mar 2017
    LATVIA
    881
    270
    500
    he keeps on going on about imperial lead screw, so I guess thread cutting is essential
    Hardinge had that headstock mounted threading adapter on HC-AT(?), if that would fit on an HSL and it had a compound slide, that might fit his requirements apart from the "new" and "supported" though I can't really imagine what support one might need for such a small thing used occasionally, it sounds more and more like he is looking for the unicorn that doesn't exist...
  18. #93
    Jun 2012
    Michigan
    14,336
    4885
    5182
    The cross handwheel being inch would be desirable to me.
    The lead screw with having a change gear would be of little matter to me.
  19. #94
    Sep 2008
    Canada
    1,722
    673
    686
    Quote Originally Posted by jz79 View Post
    Sounds to me like he doesn’t want to buy any number of used lathes that will do the job just fine for him. His money, he can waste it on something new and spendy. Or maybe just pay a machinist/shop to do the jobs for him. Heck, I live in a small town and there’s three lathes that look to be in reasonable condition in the size he wants for sale locally. Anyone of them could have been in my shop and working two days after his first post.
    L7
  20. #95
    Jun 2012
    Michigan
    14,336
    4885
    5182
    For one who would pay $30K for a bench lathe, I would want the very best.
    When I hit the lotto I might buy a WABECO and have the cross made to Imperial
  21. #96
    Oct 2005
    CANADA
    Ontario
    1,720
    576
    672
    Current production (quality) lathe + 8" swing + inch leadscrew + under 350 lbs. = Unobtanium
    I think you'll havta open up your specs a little...
  22. #97
    Jun 2001
    downhill from Twain\'s study outside Elmira, NY
    11,520
    4405
    4127
    I already posted those options way back in post #2
    Lots of old Hardinge split beds and similar makes out there.
    Qualified it at the time, though:
    ...perhaps not so easy anymore to come up with the threading and power feed parts and gears.
    But if desperation sets in, there is in fact a complete kit with threading here, gearsets, and hobs that could be cleaned up, slides scraped, and fresh paint for, oh, $29,950.00 with free delivery to MA.
    It really is a strange state of affairs that no manual lathes of that size are made in the USA anymore, bar Levin. & Levin does not offer threading. It would seem that someone could make a run of a dozen or so at a time & make a decent living off the accessories. Size it right and the armed forces are a compulsory buyer. Like for the Versamils. Which is a one man shop. But apparently not.
  23. #98
    Feb 2004
    peekskill, NY
    27,571
    6472
    I'm standing by for a clarification but by "imperial lead screw" he could be meaning "imperial crossfeed screw." Hence the specific question does he want to to do lead screw threading on the machine?
    When I want to cut threads on that small 7" lathe, I just put the turret on it and use a die head.
  24. #99
    Jun 2001
    11,520
    4405
    4127
    Will the die head do lense mounts and such?
    smt <-------multiple Geometrics for the turret, but leadscrew or chase threading opens up options.
  25. #100
    May 2017
    Minnesota
    2,256
    3124
    1647
    Pick up one of these, program threads at whatever pitch you want:
    C56A 220V ADTECH Micro Mini CNC Lathe Machine Hardware Steel Metal Woodworking 606989560735 | eBay
