Anyone have any knowledge of this tool steel alloy?
Results 1 to 13 of 13
    Oct 2009
    Seattle
    168
    5
    30
    Default Anyone have any knowledge of this tool steel alloy?
    I acquired a number of these "Bonded Carbide" steel toolbits along with some other lathe stuff, but I have never seen this alloy before, nor can I find any information on it. I kinda doubt it's just a pretty substrate for a brazed-on carbide tip, as some of these have ground cutting edges. Anyone know what this stuff is? I suspect it might be some poor quality import product. Thanks for any info or even an educated guess.
    Mike
    Feb 2007
    St. George, Utah
    875
    411
    552
    All carbide is 'bonded' isn't it? Can you grind those with normal stones?
    Oct 2009
    Seattle
    168
    5
    30
    Quote Originally Posted by Gordon Heaton View Post
    It grinds pretty much like high speed steel, except the sparks are a darker orange color (compared to high speed steel sparks).
    Sep 2006
    SW Wisconsin
    506
    17
    123
    Any time I have seen dull orange sparks on a tool bit it has been a lower quality item. They seem to work OK if you run them slow and a lighter feed.
    Ed.
    Oct 2011
    West-Central Illinois, USA
    1,239
    1998
    564
    IME high speed steels have a long bright spark stream when ground aggressively. Stellites have much shorter spark streams, which are bright orange. Tungsten carbides will be a shorter yet spark stream, and a lighter orange than stellite.
    Tungsten carbide is way heavier than HSS and stellite is in between heavier, but easily detected in the hand.
    Good luck,
    Matt
  6. Likes SAG 180 liked this post
    May 2017
    FINLAND
    1,715
    482
    791
    Quote Originally Posted by Matt_Maguire View Post
    Good luck,
    Matt
    And stellite is non-magnetic. HSS attracts strongly to magnets, tungsten carbide only mildly.
  8. Likes muckalee, Matt_Maguire, Hopefuldave liked this post
  9. #7
    May 2017
    FINLAND
    1,715
    482
    791
    Apparently there is also steel bonded titanium carbide:
    Steel Bonded TiC - Grade Selection :: Ferro-TiC SBC
    Doesnt look like really a candidate for lathe tool but its also possible that OPs blancks were intented for something else orginally.
  10. #8
    Virginia
    27,265
    7561
    8502
    Quote Originally Posted by Mikel Levy View Post
    Mike
    The "Grand Old" major makers of the HSS (and stellite) tribe do tend to have better finishes, even if showing grinder swirl, and to do a decent, even rather elegant, job of marking with a "name"(Tatung G, Rex 95) than what you foto'ed.
    So yes, looks "offshore", and with English-language markings I will SWAG India, and not necessarily even export-target.
    But WOTHELL.. just go try it. It might be usefuler that average and decent value for money at knocking-down initial passes of corncob weld or the like that tears up most tools anyway. "Cobra" were like that, and they were only ignorant T1's.
  11. #9
    Jul 2004
    N. GA- 33.992N , -83.72W usa
    3,766
    64
    865
    perhaps it is from Carbide, W.Virginia . could it be a promotional item for a bail-bonds company in Carbide
    -like ball point pens &tee shirts
    maybe not tungsten carbide . lots of other carbides .
  12. #10
    Jan 2016
    New York
    229
    63
    Default Strange Steel Alloy
    Mike
    Vanadium Carbide heat treats like tool steel at 1450 deg. Quench in oil and hardens to 70Rc. Stelite is a bonded cardide. Look it up on the internet for information. Pure speculation on my part!
    Roger
  13. #11
    Feb 2006
    Indiana
    12,862
    668
    3827
    Quote Originally Posted by tnmgcarbide View Post
    ...maybe not tungsten carbide . lots of other carbides .
    The most common carbide in tool steel is probably forgotten by most people. It is iron carbide or cementite, the stuff that makes plain carbon and alloy steels and cast iron hard when heat treated in certain ways.
    Larry
  14. Likes sfriedberg, Hopefuldave liked this post
  15. #12
    Mar 2018
    10
    5
    15
    Bonded Carbide was made by Braeburn Alloy Steel Co in Braeburn PA - I've also got some of this HSS and some of it has the name on it. From what I can tell, it's T5 or T6. The Traditional Tools Group (Inc.) -- Document View is my favorite page for identifying forgotten flavors of HSS and you can see Bonded Carbide JR and SR mentioned on the page.
  16. #13
    Jul 2006
    rochester, ny
    1,895
    380
    521
    Great source of information, thanks for posting that link.
  17. Likes bones525 liked this post
