Anyone here know what signal output on Sargon DRO scales ?
Likes Likes:  0
Results 1 to 6 of 6
    Dec 2000
    Coastal Dogpatch, SC, USA
    51,359
    2834
    5646
    Default Anyone here know what signal output on Sargon DRO scales ?
    Would like to adapt Sargon scales (already mounted to lathe) to display on Acurite or Heidenhain box if possible. Suspect the pin out on Sargon connectors is different from Acurite and Heidenhain also, yes ?
    Aug 2006
    montana
    392
    219
    156
    I had a sargon on a lathe and had work done a couple of times by the people in the link. I have adaptors going from the sargon unit to new scales I no longer need if they would work for you. Welcome to the support web site for Sargon digital readout systems. Sargon dros, linear scale, digital readouts, manuals and mounting hardware
    Feb 2013
    727
    490
    404
    I will second what ronf said. The guy at LMSC in Anaheim is very knowledgeable and they are great to deal with.
    I have bought a number of Korean made Jenix units from them that are dirt cheap and very nicely made. Haven't been able to kill one yet in 6 years. Very easy to talk to.
    Apr 2014
    Dutchess County NY
    376
    94
    91
    Quote Originally Posted by Milacron View Post
    See: Accurite 25 pin to 6 pin adapter?
    Nov 2009
    Massachusetts
    374
    122
    Quote Originally Posted by Jaxian View Post
    I installed a Jenix unit on a Millrite MVI vertical mill in 2007 and have had no problems since. Glass scale. Their resolution is 5 micron, as I recall. In inches, reads to 0.0002". I do like Jenix.
    Jul 2010
    corvallis,or
    872
    89
    366
    Sargon is standard quadrature encoding. Pinout is different, yes. I've adapted Sargon scales to work on other DRO's before. The ones I had used a DB-25 connector. Wasn't hard to figure out what was what once I got the connector jacket off.
    Somewhere I should have notes on the pinout. I'll post them if I find them.
    Edit: I'll third what ronf said. We bought a few Jenix DRO's. They seemed high quality and they will provide you with Sargon adapters as part of the sale. That being said, it isn't hard to make adapters yourself if you already have a quadrature DRO that you want to use.
    Edit 2:
    Here's a picture of one of the connectors. That's the backside of a male DB-25. I believe the green(14) is ground, blue(15) is +5V, black(1) and red(2) are TTL1 and TTL2. It's been awhile and don't have my notes so .....
