is there any vendor offering a 3-axis dro box compatible with haidenhain scales? (LS 803, 11 micro amps, 40 micro mm, vss signal.) i was quoted 1500$ for ND780. anything less expensive out there?
Dian,
The LS 803 scales are ancient. (70's and 80's) Unless I miss my guess altogether they will not work with a modern readout. You will need a VRZ 713 readout or something similar which you will have to hunt second hand. Singer may have one. I do no for a certainty that Heidenhain no longer support the old equipment.
OWen
Dian,
OWen
LS803 scales are indeed ancient.
However, one of the nice things about the ND780 is the fact it recognises and works just fine with old scales.
I run LS 803`s on my ND780, no problems at all.
Dian, for budget`s sake you could consider one of the older ND`s that are on Ebay Germany often.
Prices about €450,-.
Which one will work with your scales may be found in the manuals which are available online at heidenhain.de.
On edit : to fit LS 803`s to the ND 780 you`ll need adapter cables.
To go between the traditional round plug of the scales to the DSub connectors of the ND 780.
With the help of an electronically savy friend I made them myself.
Could dig out the schematics and part#`s I used if you`re interested.
Note : in the end not much cheaper then just buying the cables on Ebay
Notice
