rons
- Mar 5, 2009
- California, USA
I was planning on using a couple of 24VDC Asco valves to dump water from a air compressor system. Right now I have two valves that operate with 115VAC.
I called up Asco technical help with the idea that I could remove a 115VAC coil and replace with a 24VDC coil. Two things wrong with the whole idea. The valves will not operate correctly with a interchange like that. Also, even if I bought a whole new 24VDC valve the pressure limit is way below 150 PSI. Something like under 50 PSI.
Stuck with high volt controls.
