Clint,
Go to:
http://www.atlas-press.com/servicebulletins.htm
for copies of Atlas bulletins regarding lubrication, back gear, spindle removal, etc..
You may need to look close at your lathe when comparing to these bulletins, as there are differences among the models (e.g. my backgear spindle lube is a setscrew on the shaft, not in the pulley).
Also, give them a call. They can supply some documentation (parts lists/diagrams and price sheets).
There are phone numbers at the web page:
http://www.clausing-industrial.com/
Not sure if those are the right numbers, but you want to talk to Jolene Olds. Be sure to have your model number. She'll fix you up with documentation.
They might have the book "Manual of LATHE OPERATION and Machinist Tables" that covers your model. You should get it.
Bulletins and other type of documentation (for accessories such as the taper attachment and tool post grinder) they have sent me for free. Not sure what the price on the book is.
I noticed that you also have the cast iron legs. You should bolt that to the floor and not have it on any kind of rubber feet. I did, and I could measure deflection with a DTI in the toolpost when I pushed on the lathe bed. I now have it on the floor resting on leveling shims and will bolt it down when it moves to its final location.
Steve
