Terry Keeley
Titanium
- Oct 18, 2005
- Toronto, Canada eh!
what item slips on the end of the rotor shaft that's held on by the threads...a saw flange or something. That spacer is a crush sleeve of sorts for whatever is out on the end of the shaft..right?
Stuart
The rear axle bearings for a 57 Buick have a heavily pressed on sleeve similar to yours as a bearing retainer. The factory method to remove the sleeve is to drive a cold chisel into the side of the sleeve. That stretches it and it gets finger loose well before the chisel gets through. Then the bearing is easily pulled. Just sayin.............Bob
Sounds like the sleeve is junk after the 'Buick' operation and must be replaced.
I think the OP will be able to reuse his sleeve.
Stuart
Notice
