Bill D
- Apr 1, 2004
- Modesto, CA USA
I am replacing both ball bearings on the arbor of my tablesaw. One is fairly loose a slide fit to allow thermal expansion. I think that should be a dry so it does not accumulate sawdust and get stuck. How about the fixed bearing. It is a tighter fit into the bore. After partial assembly it is forced into the bore by a threaded collar.
So in general should bores be lubed with light oil which would seem to make assembly easier or does it dry out and glue things together so tight they will be hard to take apart in ten years or more?
Of course as I get older I begin to worry less about the need for maintenance in a few decades.
Bill D
Bill D
