sandiapaul
Titanium
- Mar 19, 2004
- Princeton, NJ USA
Hi,
I'm getting a new Prototrak mill and to get it into my shop I need to remove the table. I have had several knee mills totally apart, but I understand the ball screw should never be separated from the nut.
I need a sanity check...if I remove the right hand bracket with the handwheel and the other end with the servo and also the gib I should be able to slide the table off leaving the screw in the nut attached to the machine. Is this correct?
I found this old post saying that but I want to make sure of it. I will be doing this in a dimly lit warehouse so I want everything to go right.
Posted by J Henricksen in 2008
"Removing the table is the same as with regular screws, remove the end bearing supports, pull the gib, and slide the trable off the saddle leaving the screw in the nut on the saddle. Take the nut and screw out after the table is off. To take the nut off the screw, Rockford Ball screw uses cardboard sleeves that keep the balls in their channels in the nut. I've used alu tubing wrapped with vinyl electrical tape too. If you are going to do a screw rebuild, you can remove the nut from the screw and catch all the balls in a pan. Count the balls, and put half in one channel, the other half in the other."
