Bar runout
Likes Likes:  0
Results 1 to 6 of 6
Thread: Bar runout
    May 2021
    CANADA
    Ontario
    8
    Default Bar runout
    Hello everybody,
    I need to make a lot of parts from 4' long bars, O.D. is 1.750" we don't touch it, inside boring to 3.150" depth, eccentric tolerance is .005 ". I use a bar puller and put 3 plastic sealing rings inside the machine tube. There is almost no runout near the collet, but at the end of the bar it is about .01 ", but not always, sometimes runout is OK - .002", I cannot fix this problem. What to do? Can the Spindle Liner help?
    Jan 2014
    Chicago
    159
    59
    60
    Quote Originally Posted by edtcadcam View Post
    Hello everybody,
    Can you run the bar only an inch or two (or flush even) out of the collet? Then drill/bore past the front of the chuck. This might require you to pull the bar before part-off, but if you do it right you can start the endwork on the next part immediately.
    Second option is a steady rest to pull the bar to center when it is hanging out far from the chuck.
    Sent from my SM-G930P using Tapatalk
    Mar 2002
    dallas,tx
    2,689
    757
    556
    I've walked but never ran. Sorry couldn't resist.
    Jan 2007
    Norfolk, UK
    21,387
    16754
    17461
    Use centreless ground (aka PG) bar - drawn bar is seldom truly round or straight.
    Oct 2005
    22,008
    Hello everybody,
    Why doo posters "cross post" ???.....
    Corfusing at best.
    Bar runout
    Oct 2005
    22,008
    ..and post, post some more....:
    Attention SL20 owners
