Bar runout
edtcadcam
May 30, 2021
Toronto
Hello everybody,
I need to make a lot of parts from 4' long bars, O.D. is 1.750" we don't touch it, inside boring to 3.150" depth, eccentric tolerance is .005 ". I use a bar puller and put 3 plastic sealing rings inside the machine tube. There is almost no runout near the collet, but at the end of the bar it is about .01 ", but not always, sometimes runout is OK - .002", I cannot fix this problem. What to do? Can the Spindle Liner help?
Hello everybody,
Can you run the bar only an inch or two (or flush even) out of the collet? Then drill/bore past the front of the chuck. This might require you to pull the bar before part-off, but if you do it right you can start the endwork on the next part immediately.
Second option is a steady rest to pull the bar to center when it is hanging out far from the chuck.
Sent from my SM-G930P using Tapatalk
Hello everybody,
Why doo posters "cross post" ???.....:nutter:
Corfusing at best.
Bar runout
