sendithard
- May 18, 2021
I'm new to CAM, but plenty of CAD experience. I'm looking at some gcode from a simple part. The G18 G02 is going counterclockwise when viewed from a typical front view in CAD. The typical front view of a part is you staring at the part from a -y distance. Why is the G02 created as if you are staring at the part from behind or in some +y distance?
Also, I saw in an autodesk paper that the below code is an ending code:
G91 G28 Z0.
G90
I don't understand why you put the machine in incremental mode(G91) to tell it to go to its machine home(G28). And why put the Z0 in there? From my ignorant understanding I would just put a simple G28 in there. Why the need for the other stuff?
Thanks for your time.
G91 G28 Z0.
G90
