Bill D
- Apr 1, 2004
- Modesto, CA USA
I need to buy or make a simple lock ring that threads into a bearing bore. This pushes the bearing down into the bore and keeps it in place. It is notched on the outside end so a hook spanner can be used.
I do not know the correct name so all I can find is ones that are internal threaded and bear on the rotating shaft. The kind I need is external threaded so it engages the bore and holds the outer race in place. Obviously the diameter and threads depend on the outer race diameter.
Bill D.
Bill D.
