Bearing exetrnal threaded lock ring...name of part
Results 1 to 15 of 15
    Apr 2004
    Modesto, CA USA
    6,814
    1136
    Default Bearing exetrnal threaded lock ring...name of part
    I need to buy or make a simple lock ring that threads into a bearing bore. This pushes the bearing down into the bore and keeps it in place. It is notched on the outside end so a hook spanner can be used.
    I do not know the correct name so all I can find is ones that are internal threaded and bear on the rotating shaft. The kind I need is external threaded so it engages the bore and holds the outer race in place. Obviously the diameter and threads depend on the outer race diameter.
    Bill D.
    Sep 2009
    Phoenix,AZ
    1,757
    2680
    442
    I would expect those are application specific, you most likely will have to make.
    Sep 2017
    South Carolina
    475
    364
    393
    Drag link keeper nut? Here are pictures of the removal tools.
    https://www.mscdirect.com/industrial...l-sockets.html
    Oct 2014
    Maine
    831
    84
    393
    Bosch makes some, but they use a pin spanner. I've never seen one designed for use with a hook spanner, because then it couldn't be flush.
    Threaded Rings GWR | Bosch Rexroth AG
    Apr 2004
    Modesto, CA USA
    6,814
    1136
    Quote Originally Posted by DanielG View Post
    Something like that. This is used on a Delta tablesaw to hold the main arbor bearing in. It does stick out a little beyond flush when fully seated. Designed around 1930 so I know threads will be inch but may be a weird diameter. The original was brass and previously owner destroyed the notches trying to remove it.
    Bill D.
    part 359 on this diagram: looks like a pipe nipple notched on one end.
    Replacing the Arbor Bearings on the Delta Rockwell 12-14” Tablesaw (34-395) - VintageMachinery.org Knowledge Base (Wiki)
    Mar 2009
    Eureka, CA
    3,725
    736
    1275
    That really should be a easy and fun part to make yourself.
    Stuart
  7. Likes digger doug, Ray Behner liked this post
    Langley, B.C.
    1,664
    335
    971
    ...Bosch makes some, but they use a pin spanner. I've never seen one designed for use with a hook
    spanner, because then it couldn't be flush...
    Yeah, using a pin spanner allows the nut to be flush or even inside the housing. Nuts like that are used to retain and pre-load
    the differential side bearings on Ford 9" rear ends. I have a vague recollection of seeing nuts with slots which would enable them
    to be tightened with a ring spanner but I can't dredge up anything useful.
    Incidentally--and totally off topic--the part number on the boxes in the picture indicates that that part was from 1966. I know this
    because I drove a '66 1/2 ton for years and all the part numbers for it started with a "C6". That was back in the day when you
    could actually afford to buy parts from a Ford dealer...
  9. #8
    Sep 2005
    il.
    6,637
    30
    1213
    Whittet-Higgins Company
    these guys are pretty spectacular for locking devices
  10. Likes sfriedberg liked this post
  11. #9
    Jan 2016
    New Jersey
    216
    66
    95
    Quote Originally Posted by wippin' boy View Post
    Their website isn't great but their stuff is carried by Motion Industries.
  12. #10
    Apr 2004
    Modesto, CA USA
    6,814
    1136
    If I make it from PVC pipe would that work? I could glue in some smaller diameter to make a thick wall pipe and make it pin drive. Or I will buy some thick dom pipe.
    Bill D
  13. #11
    Oct 2010
    Oregon
    5,069
    4293
    1828
    Bill D, PVC doesn't seem like an appropriate material for this purpose. Among other things, I would expect it to creep, quickly releasing the locking force.
  14. #12
    Sep 2016
    CANADA
    Ontario
    48
    6
    Google SKF bearing lok nuts
  15. #13
    Jul 2012
    Washington
    2,823
    1085
    1128
    Speith nuts are what is used in my spindle. They are real nice.
  16. #14
    Jan 2007
    Flushing/Flint, Michigan
    7,718
    385
    6435
    Quote Originally Posted by aliva View Post
    The op needs the inside out version of these. Rare ducks and normally custom.
    Threads on the OD.
    Bob
  17. #15
    Apr 2004
    Modesto, CA USA
    6,814
    1136
    Threads on the OD.
    Bob
    Lucky for me Delta used the same bearing and locknut on a disk sander that I am slowly restoring so I can borrow that retainer and have plenty of time to make a new one. It is 2" od so just a hair bigger then standard water pipe.
