Bearing-guided round-over and bevel bits for steel plate?
ballen
Sep 25, 2011
Garbsen, Germany
One of my go-to woodworking tools is a set of bearing-guided bits for doing small-radius roundovers and bevels on edges. I put them into a 2HP Bosch hand-held router or a smaller trim router and run them around the edges of parts. I have also used the woodworking bits with aluminium and brass, sprayed with a bit of WD40 as a lubricant and to prevent buildup on the cutting edges.
Does someone out there make a similar bit out of carbide or ceramic which can be used on mild-steel plate? For appearance I'd like to treat the edges of some steel plates. Sure I can do it on the mill but the setup will take 20 times as long as if I could use a hand-guided tool. I'd be happy with roughly 3mm (1/8") wide bevels or roundovers, so we are not talking about removing a lot of meat. (I have not tried this with a woodworking bit but am 99% sure that the carbide would fragment when run on steel. I think different material and/or relief angles are needed.)
I'm lost..are you implying you would use a typical hand router with a guided bit suitable for steel to slightly dress the edge of a steel plate..a hand held router that spins at 20K?
Stuart
you really need a carbide burr . the stationary chamfering machines use a cylindrical cutter with an angled base .
you could use a conical burr, and modify the routers' bases with a vertical fence , mount outboard roller guides to the
base instead of the cutter , or a combination of both .
VS routers can turn at 8k rpm , and most die grinders run 18-25k rpm.
I have used a carbide tree burr with a collar in my variable speed router on various occasions to dress plate steel from a shear. Just don't try it on a flame cut edge.
Thanks. I'm not looking for a machine, but rather for a bearing-guided bit with a 1/2" or 12mm shank that I can put into a hand-held woodworking router.
And I'm just pointing out the sort of tooling it takes to do the job.
This ain't a hobby shop for kids.
But you could check with harbor freight, they must have something.
I use the 4flt Freud wood bits with 1/2 shanks in a vmc, 12,000 rpm with the bearings removed all the time in aluminum. A few years back an employee forgot to remove some hardened steel hold downs for an aluminum part he was running, I was very supprised at how nice a radius it put on the hold down, he stopped the machine after it cut about an inch and a half, it broke a corner above the radius but all in all it survived. You might just try one, conventional cut with oil and see how long it lasts.
Thanks, I just read about carbide burrs, that seems like a good solution. I can use a 90 degree countersink burr with a 1/4" or 6mm shank running in a router set to 10-15k rpm. Can I make a 3mm (1/8") wide bevel in mild steel in a single pass or will multiple passes be needed? Do you recommend single cut or double cut?
The only place this might not work is on some curved edges, where I really need a bearing-guided cutter. But most of the edges are straight.
I also use ball-bearing router bits as you describe, including with aluminum. I would say that a standard 2-flute chamfering tool MIGHT survive for a while cutting steel in a highly-controlled rigid spindle machine (as Kustomizer referenced), but in a hand-held router, I also think you'll lose the carbides fairly quickly. In my experience, on aluminum a rough and finish cut (climb-cut) are required for a "nice" finish, and aluminum has considerably more resistance to material removal than plastics or wood. I think a 3mm radius or bevel in steel would require several passes at lower RPM (= more effort to push through cut, more chance to break something) and none of those would be climb-cutting;-) Chances are it's not something I would enjoy doing.
Burrs are the tool of choice, from what I have seen in steel edge finishing. Whether anybody builds them with tracing bearings is an open question. In the choice of single or double cut, I would just look at whether a single helix direction is going to give trouble with feeding material. The double cut is likely more fragile in tooth config, but maybe more stable for hand work.
For curved surfaces you could use a follower bearing attached to the router base, as in laminate trimmers.
I've cut aluminum and brass on a heavy woodworking shaper w/ lock edge hss knives. Kinda scary, the chips are like shrapnel, made myself a plywood apron! And I knew a guy who routed a groove in the cast iron top of a new Martin table saw to install a long flexible Starrett ruler. He just used a 2 flute carbide bit.
I did something similar recently. I had intact cemented some 18 ga mild steel to a 3/4” plywood base. Th steel hung over the edge of th plywood in a couple of places and I wanted to trim it up. I used a 1/2” 2 flute carbide bit. It did the job, was very scary and pretty much ruined the but. Good luck.
Sent from my iPad using Tapatalk
