wehnelt
- Apr 13, 2007
- California
I’ve been looking at spindle designs and am having a hard time understanding what parts are press fit and which are slip fits. Let’s suppose I have a bearing arrangement where there’s a pair of angular contact bearings pressed onto the end of a shaft with their associated spacers. This is a setup meant to take both radial and axial stiffness, and once tightened, there’s axial preload. Then I want to drop this into a housing that has a precision bore. Should both bearings be press fit on both the shaft and the housing? Should one? Should neither? Where does the bearing setup’s radial stiffness come from if both bearings have radial clearance?
