bearing removal suggestions
Results 1 to 12 of 12
    Oct 2016
    Indiana
    99
    10
    Default bearing removal suggestions
    Looking for suggestions on prying or pulling the bearings from a Harrington chain fall.
    I have no access to the other side of the bearing and was curious the best method on removal.
    Thank you,
    Feb 2004
    peekskill, NY
    27,591
    6486
    Is the housing aluminum? If so heat with heat gun or in oven, turn over and the bearings will fall out.
    Jan 2015
    Missouri
    1,642
    239
    1039
    Slide hammer
    Oct 2010
    Oregon
    5,879
    5887
    2284
    If you don't need to save the existing bearings, this is rather easier. Slide hammer with bearing puller jaws or a pilot bearing puller. Heating the housing will help.
    If you do need to save the existing bearings, you can't yank on the inner races, and there's almost certainly no way to get a shop-made jaw through the ID and under the outer races. I'd drill small holes in the house aligned with spots on the outer races, and use pin punches. Or, drill small holes, tap them (be clever about grinding points off taps to work with the limited space (if any) between race and housing), and jack the bearings out using machine screws in the tapped holes.
  5. Likes Joe Rogers liked this post
    Apr 2004
    Modesto, CA USA
    8,947
    1774
    Agree slide hammer with a little expanding finger hook setup to pull from the back side.
    Bill D
    like this one:
    OTC 1172 PULLER SLIDE HAMMER PILOT BEARINGS 1/2 TO 2 INCH | Tool Discounter
    Or get fancy with OTC. I have never seen this type before. Looks very nice, and expensive.
    Amazon.com: OTC 4581 Slide Hammer and Blind Hole Bearing Puller Set : Automotive
    Dec 2018
    UNITED KINGDOM
    Knock the bearing cages out. Put all the balls to one side and pop out the inner race. Then run a bead of weld around the outer race (where the balls run)
    When it cools it will shrink and drop out.
  8. Likes Metalsling2 liked this post
  9. #7
    Feb 2011
    BFE Nevada/San Marcos Tx
    3,349
    3303
    2103
    Blind hole bearing puller, HF has a decent and inexpensive one if you are on a budget.
  10. Likes 4GSR liked this post
  11. #8
    Oct 2016
    Indiana
    99
    10
    Quote Originally Posted by jim rozen View Post
    The heating method worked.
    Also, thanks for the other suggestions, the tool that was suggested will work next time when I remove my new ones, these can and were damaged by the heat (which was OK).
  12. #9
    Jun 2012
    Eastern PA
    1,185
    399
    580
    None of the tools suggested will remove the bearings without damaging them.
  13. #10
    Aug 2014
    bainbridge island
    1,488
    324
    375
    Quote Originally Posted by awander View Post
    disagree. static axial load that a standard radial ball bearing can handle is half of the radial load.
    the problem is that its easy to put thousands of pounds of force on the bearing with a slide hammer. instead use static loading and then heat the casing, or try inverting one of those "canned air" cans and spray the bearing with -25F freon.
  14. #11
    May 2020
    Minnesota
    581
    239
    245
    Tried the paper towel and grease trick?
    Good part starts at 4:30.
    Hoo-drolik pressure!
  15. Likes steve45 liked this post
  16. #12
    Feb 2004
    peekskill, NY
    27,591
    6486
    Except the heat gun.
  17. Likes Metalsling2 liked this post
